NEED HELP no compression on #2 cyilinder
Old Oct 6, 2007 | 08:58 AM
B18C5_VTEC's Avatar
Default NEED HELP no compression on #2 cyilinder
hi, i have a b18c5 and i recently changed the cams. when i changed the cams the timming belt slipt and i ended up doing a compression test and #1,3,and 4 where fine, but #2 had no compression at all. soo, i took of the head brought it to a machine shop and they replaced only the intake valves, becuase they looked bent. i know that it is problubly the exhast valve that is bent, but before i take the head off again i just wanted to make sure it was nothing eles. i have also checked the valve clearence. thanks
Old Oct 8, 2007 | 02:48 PM
b16bluva's Avatar
Default Re: NEED HELP no compression on #2 cyilinder (B18C5_VTEC)
there's only a couple of things that can cause a loss of compression in a cylinder...
-The compession rings are leaking/ broke/ missing
-Your head gasket is messed up/ not sealed correctly
-Your valves are bent: exhaust or intake or both
-You valve springs aren't returning your valves to close position
Old Oct 8, 2007 | 02:54 PM
Duane_in_Japan's Avatar
Default Re: NEED HELP no compression on #2 cyilinder (b16bluva)
You need to get a leak down test done at a shop so you dont have to do this job three times.
acman1
May 21, 2007 12:06 PM
leeminho86
May 18, 2006 08:14 AM
slowazzhatch
13
Jun 1, 2004 08:51 AM
RGoose18
May 21, 2004 10:13 AM
