static compression ratio
Old Oct 6, 2007 | 08:51 AM
slammed_93_hatch's Avatar
Default static compression ratio
I have a question about the static compression ratio for this motor combo. It has been along time since i have messed with B series motors so i am not sure.
B16a block, and crank, with CTR pistons, and a GSR head.
IIRC the gsr combustion chamber is different the b16a and b18c1/5 and i thought it neted more compression...
Thanks for the help
Also what would the static compression ratio for this motor be?
I asked this in the hybrid forum and got nothing
Old Oct 6, 2007 | 12:21 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: static compression ratio (slammed_93_hatch)
It would be around 11.6-11.8:1 but you will need to do some clearancing on the ctr pistons to get it to work with th gsr head.
Old Oct 6, 2007 | 02:53 PM
Default Re: static compression ratio (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">It would be around 11.6-11.8:1 but you will need to do some clearancing on the ctr pistons to get it to work with th gsr head.</TD></TR></TABLE>
Same clearence that i would need to do with a B16/B18c5 head correct?
The pistons are already cut.
Old Oct 6, 2007 | 03:41 PM
Aquafina's Avatar
I got 12.43:1.
No decking/milling. 81mm bore, no VJ, no machining the pistons.
-.0157 P-D using the compression height listed on theoldone (only place I could find the compression height measured versus figured up).
Take this with a grain. I've never touched a PCT piston myself.
Old Oct 7, 2007 | 04:44 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
The pistons are already cut.</TD></TR></TABLE>
Here's a link to a recent post with a similar question and a couple pics for reference. From what I understand you shouldn't have to modify a b16/18c5 head to use these pistons, just the GSR head.
https://honda-tech.com/zerothread?id=2110763
Looking at the numbers again, you'd probably be right around 12:1, roughly in between my and Aquifina's best guesses.
Old Oct 7, 2007 | 04:51 PM
thanks for the info guys.
slammed_93_hatch
Oct 10, 2007 08:04 PM
93_delsol_si_gsr
Sep 20, 2006 06:11 PM
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
ek9dc2
Oct 13, 2003 08:12 PM
AllMoToRB18c
Jun 29, 2003 02:56 PM
