FMU question??
How do i set my fmu and how do i know what to set it at? When i "get on it" my check engine light comes on, i have been told it's from having to much air and not enough fuel.
Thanks Kyle
Thanks Kyle
what kindof fmu is it, most are not adjustable, if your running a turbo on stock engine typically people run 12:1, which means 12lbs of fuel (above stock) per 1lb of boost psi
b18b1 87mm bore 9.2.1 compression aries rods eagle pistons xs power header xs power turbo kit oversize front mount greddy exaust msd ignition cap coil aem fuel rail crower stage 2 turbo cams cam gears(forget what brand) new valve springs guids and double spring(forget what brand)...i think that's it
vortech fmu...would the porblem with the check ingine light be with the fmu or would it be the i need a new ecu and injectors(which i plan on getting when i have the money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg185 »</TD></TR><TR><TD CLASS="quote">would it be the i need a new ecu and injectors(which i plan on getting when i have the money)</TD></TR></TABLE>
Yes, you need a tuneable ECU, upgraded injectors, and some proper tuning.
tune that **** before it blows up. i bet you're not even using a missing link which would cause the CEL. and 87mm bore with turbo and xs power turbo and manifold?
So let me get this straight, you build the engine and then buy the cheapest possible turbo parts you can find and wonder why it runs like ***?
This isn't 1994...there are plenty of cheap tuning solutions. There is no reason to ever contemplate using an FMU. Those things are archaic.
Thanks, i only rani it a couple times and when that **** started happening i stopped...i bought the car with the turbo kit on the stock engine, i had no idea xs power is such bad brand i'm pretty new to this building stuff but thanks again for the help
its not that xs is a bad brand, its just a cheaper brand, i got a xs wastegate, and it works great it might not last as long as a tial but hell it was the third of the cost i thought it was worth a shot, besides that the majority of people on here have never owned a xs power brand anything, so there not really entitled to talk smack about them. most people have only heard of problems with xs and automatically think that its crap cuz it was cheap, but iv seen problems with greddy and other name brands to but no one talks crap about them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian »</TD></TR><TR><TD CLASS="quote">So let me get this straight, you build the engine and then buy the cheapest possible turbo parts you can find and wonder why it runs like ***?
This isn't 1994...there are plenty of cheap tuning solutions. There is no reason to ever contemplate using an FMU. Those things are archaic.</TD></TR></TABLE>
Your FMU is probably not working correctly. Usually when it detects boost pressure, it will put in more fuel pressure. If you are running more then 8 PSI you should consider a different form of fuel/computer managment.
