Honda S2000 Honda S2000
Test Pipe - Exhaust Fumes
Old Oct 5, 2007 | 04:36 PM
jdm j's Avatar
Default Test Pipe - Exhaust Fumes
(To anyone running a test pipe) Can you smell the exhaust fumes in the cabin area very strongly with your test pipe on? How about with the windows up? I'm driving around and I'm smelling the exhaust fumes like whoa. Anyhow, my engine is fine, I just might have an exhaust leak that's all. What are your experiences? Smell? No smell?
Old Oct 5, 2007 | 04:41 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Test Pipe - Exhaust Fumes (jdm j)
make sure u have no leaks.. but otherwise thats just the smell of the toxins your car is suppose to contain
Old Oct 5, 2007 | 04:47 PM
papa5murf's Avatar
No smell, unless I'm reversing. Then I can smell it. Or if I'm at a stop and there's a gust of wind from behind.
Old Oct 5, 2007 | 04:56 PM
b20integrapower's Avatar
normal i guess, but it will be more noticable in certain conditions.
Old Oct 5, 2007 | 05:33 PM
llxzxll's Avatar
Default Re: Test Pipe - Exhaust Fumes (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">No smell, unless I'm reversing. Then I can smell it. Or if I'm at a stop and there's a gust of wind from behind. </TD></TR></TABLE>
also right after i park at home and get out of the car. hate knowing that with ever wiff i'm killing brain cells.
Old Oct 5, 2007 | 07:02 PM
LAS2K's Avatar
Default Re: Test Pipe - Exhaust Fumes (llxzxll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llxzxll &raquo;</TD></TR><TR><TD CLASS="quote">
also right after i park at home and get out of the car. hate knowing that with ever wiff i'm killing brain cells.</TD></TR></TABLE>
So you must not drink alcohol then? Each drink kills 1000 brain cells.
Old Oct 5, 2007 | 07:14 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Test Pipe - Exhaust Fumes (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">
So you must not drink alcohol then? Each drink kills 1000 brain cells. </TD></TR></TABLE>
im soooo FUUCKED
Old Oct 5, 2007 | 11:36 PM
Black S2K's Avatar
Youll allways smell it no matter what but it shouldnt be that bad with the top up and the windows up. I got used to it a while back I run a tp on everycar I own.
Old Oct 6, 2007 | 12:04 AM
Raabjorn's Avatar
No smell here. If your exhaust system is brand new, it can smell a little in the start. It did so in my ITR...
Old Oct 6, 2007 | 04:25 AM
llxzxll's Avatar
what's alcohol?
Old Oct 6, 2007 | 05:30 AM
E-Money's Avatar
theres most likely a exhaust leak
Old Oct 6, 2007 | 07:20 AM
LAS2K's Avatar
what's alcohol?</TD></TR></TABLE>
Jesus juice.
Old Oct 6, 2007 | 07:42 AM
LumpyTheGrumpyCamshaft's Avatar
you drive a s2k cause it drives like a s2k, smell should be somewhere down the list from, 3rd 4th and 5th gear
chino2x2x2x
Jun 23, 2007 02:11 PM
Spo0NFed E M 1
Jul 1, 2006 08:21 AM
DoyouVtec
Apr 27, 2006 05:54 AM
:jdmshmaydm:
Feb 3, 2004 06:38 AM
HX_Guy
Sep 8, 2001 09:59 AM
