Lower Timing Cover bolts
How many are there? I've got three out the bottom, and two at the top, the dipstick bolt. Are there more? Doesn't say in the helms.
Modified by vinuneuro at 6:10 PM 10/5/2007
Sorry I dont have a pic, you do have the harmonic balancer off too, correct, you should be able to see all the bolts but there may beone kind of hidden, sunken into the cover in the center region.
Yep, I've got the crank pulley off. Per the helms it looks like only the cotter pin on the maintenance bolt is the obstacle in the middle of the cover.
I dont remember any cotter pin, I think the maintenance bolt is something you supply yourself to hold tension on the belts while you do some related work in the area??? Do you have a build up of dirt around the bottom of the timming cover.
windnsalsa
Apr 4, 2018 07:47 PM
JigsN Joints
Sep 23, 2011 01:30 AM
FUP23
Aug 10, 2002 08:56 AM
