better ride!!
depends what springs/coilovers you run, the spring rates, and how low you are dropped.
i'm pretty certain though that the kyb agx will give you a better ride simply because they are adjustable. if you are considering the agx, i would personally hold out and get tokico illuminas instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_bitik »</TD></TR><TR><TD CLASS="quote">i know the agx has a good ride. 1 rides like the stock 4 auto x time!!! i like it!</TD></TR></TABLE>
true... had the same experience with them.
i have a teg right now that is running on tokico blues w/ hnr drop springs...
rides alrite
i have another teg with kyb agx adjustable with skunk2 drop springs....
never rode in it
i want to keep the better one but dont know which on rides better and i dont wanna change out the tokico's for kyb if it rides worst but from what im hearing th kyb are much better.
rides alrite
never rode in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie »</TD></TR><TR><TD CLASS="quote">depends what springs/coilovers you run, the spring rates, and how low you are dropped.
i'm pretty certain though that the kyb agx will give you a better ride simply because they are adjustable. if you are considering the agx, i would personally hold out and get tokico illuminas instead.</TD></TR></TABLE>
What I was going to say.....it also depends on the tires you roll on. A lower profile tire will give you a stiffer ride as well.
