Quick Question about my YS1 transmission.
Old Oct 5, 2007 | 11:38 AM
1uncleanDA's Avatar
Default Quick Question about my YS1 transmission.
I just changed my transmission fluid. But I when to put the fill plug back in I think A little bit to much spilled out. Is there anyway I can add some more with out going through the fill hole? VSS
Looks like mine
Thank You
Old Oct 5, 2007 | 01:14 PM
myfirstdc2's Avatar
Default Re: Quick Question about my YS1 transmission. (1uncleanDA)
what do u mean a lil of it spilled out? your suppose to fill it up until the fill hole spills out then plug it up. and while your filling it up the car should be level in case if slanted in a way that the level of fluid is towards the fill hole and then u would underfill it. should be about 2 qts
Old Oct 5, 2007 | 01:43 PM
1uncleanDA's Avatar
Default Re: Quick Question about my YS1 transmission. (myfirstdc2)
Yes I know. I Had trouble with the angle i was at to get that bolt back in, so i jacked the car up a little more....That were the extra came out.
Can anyone answer the question?? of adding more without doing it through the fill hole.
Old Oct 5, 2007 | 01:55 PM
PACT man's Avatar
Yes, you can do it through the VSS hole if you pull it out of the way. The tranny takes about 2.4-2.5 quarts not 2.
Old Oct 5, 2007 | 02:07 PM
myfirstdc2's Avatar
if u want to get technical then its 2.3 qts but usually it'll be around 2 qts cuz not all of it will drain out unless u let it sit there for awhile. anyway if u do it thru the that hole then u wont know the proper level unless it thru the fill hole , its up to u its your car your tranny.
Old Oct 5, 2007 | 02:47 PM
1uncleanDA's Avatar
Thank you. What number is the VSS on the diagram at the top?
Old Nov 13, 2007 | 03:11 AM
Mfoehrkolb's Avatar
i dont see it marked on your diagrapm. but there it is. that orange thing on the picture is intake. and underneath is the VSS. couldnt find a better picture. sorry. hope it helps.
DC5mike
Nov 29, 2008 01:29 PM
ajwiant
Mar 4, 2006 08:33 PM
Aphelion
12
Feb 8, 2005 04:06 AM
eL
10
Jan 30, 2005 04:02 PM
imadigitalgod
Oct 22, 2004 08:33 AM
