Skunk 2 Pro Series Intake Manifold Info/Help
Old Oct 5, 2007 | 11:04 AM
type-GGSR's Avatar
Default Skunk 2 Pro Series Intake Manifold Info/Help
i know people have posted about the gsr intake manifold comparing it to the skunk 2 intake manifold but none of the posts really answered the question that i have. My question is, the stock gsr intake manifold is the butterfy which has that primary and secondary vtec(sorry i still dont understand it well haha im noob ). If i get a Skunk 2 Pro Series Intake Manifold, when will Vtec hit? I heard the Skunk 2 Intake Manifold works so that vtec doesnt go through that dual stage. Also is it better if i do get a Skunk 2 Pro Series intake Manifold or should i just stick with my stock GSR intake manifold. By the way, my car is stock except for the intake.
Old Oct 5, 2007 | 01:08 PM
all-mtr-teg's Avatar
Default Re: Skunk 2 Pro Series Intake Manifold Info/Help (type-GGSR)
Stick w/ your oem GSR intake unless you get some cams and want your power up top. Stock GSR IM works great for mid range. I learned the hard way and got a Skunk2 IM before my cams and the car was slower than before the install. Then i got BC3 cams and moved vtec to 5800 rpm, and car runs a lot better.
Old Oct 5, 2007 | 09:54 PM
doood's Avatar
been there done that
Default Re: Skunk 2 Pro Series Intake Manifold Info/Help (all-mtr-teg)
first, there is only one vtec and that's at 4400rpm.
second, replacing your intake manifold with a single runner manifold like a skunk2 has no effect on vtec. it'll keep on engaging at 4400rpm until you change it in the ecu.
third, a single runner manifold is not a good mod until you have at least cams.
fourth, maybe a visual aid will help:
Old Oct 5, 2007 | 11:53 PM
GSR in progress 96's Avatar
* B A N N E D *
Stick with the stock one untill you put cams in. I made the mistake of changing mine and I now regret it.
Old Oct 6, 2007 | 12:38 AM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: Skunk 2 Pro Series Intake Manifold Info/Help (GSR in progress 96)
all i herd is even with stock cams get a chipped ecu and you shud be fine you make lesser power if you keep that crappy stock gsr ecu you need it chipped
Old Oct 6, 2007 | 12:48 AM
type-GGSR's Avatar
Default Re: Skunk 2 Pro Series Intake Manifold Info/Help (DOHCgarage919)
oh man. Thanks alot guys, really appreciate it.
Old Oct 6, 2007 | 12:49 AM
did you chip ur ecu???? if not theres your problem
Old Oct 6, 2007 | 01:09 AM
type-GGSR's Avatar
No my ECU is stock.
Old Oct 6, 2007 | 09:46 AM
you will need to chip it to get the gsr runnig right cuz ur stock ecu is for the 2 runners vtec crap heres where i chipped mine and a ressonable price http://www.phearable.net
Old Oct 6, 2007 | 09:52 AM
1.8L_allmotormilitia's Avatar
skunk2 IM.
Old Oct 6, 2007 | 10:00 AM
Default Re: (1.8L_allmotormilitia)
Blox Im
skunk2 IM
Old Oct 14, 2007 | 08:25 PM
type-GGSR's Avatar
Default Re: (DOHCgarage919)
okay im lookiung at different responses form people and i still dont know wut to do. Should i stick with my stock GSR IM or get a skunk2 pro series.
Old Oct 14, 2007 | 08:52 PM
Exeed's Avatar
Default Re: (type-GGSR)
Basically what the guys are trying to say is, if you keep your stock GSR cams, changing the IM will not benefit you, in terms of power. So if you're going to change to a single runner IM (i.e. skunk2, blox or whatever) be sure that you've changed your cams first.
Kyle41791
Feb 19, 2010 08:27 AM
19992civichatch
Mar 21, 2007 07:37 AM
tegh22a
33
Aug 6, 2006 08:43 AM
