Timing belt help
Old Oct 5, 2007 | 09:23 AM
dhn's Avatar
dhn
Default Timing belt help
so i borrowed the moroso tool from a friend...and im an idiot and have no idea how to use it.has anyone used it?..if so any help? also is it necessary to remove the alternator and ps pump for the timing belt? im doing a ini me and the head is almost off im just tuck on the timing belt, i checked the timing belt thread but they are using a different method
Old Oct 5, 2007 | 10:53 AM
dhn's Avatar
dhn
please help
Old Oct 5, 2007 | 12:21 PM
dhn's Avatar
dhn
please any help at all guys
Old Oct 5, 2007 | 12:35 PM
circuitEG6's Avatar
Default Re: (dhn)
you dont need to use that just look at the little timing indicatiors...not sure what motor you have but there little notches...when you have them lined up thats TDC (top dead center) just take some white out and mark all the pulleys where they are then at that moment and just remove the serpentine belts via the tensioners and then the timing belt which im sure you already knew lol. Are you replacing the water pump??
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Timing belt help (dhn)
What kind of car?
What's the "Moroso tool" look like, and exactly what it is intended to do/claims to help you do?
Old Oct 5, 2007 | 01:26 PM
dhn's Avatar
dhn
1992 civic cx with d15b8..going to put a z6head on it...im just having a problem with the moroso tool..supposed to hold the crank pulley still ig uess
Old Oct 5, 2007 | 04:40 PM
jbfw's Avatar
is this tool supposed to hold the crank pulley so u can break it loose? i would just use an impact wrench to loosen the pulley so you can adjust everything
Old Oct 6, 2007 | 06:51 AM
dhn's Avatar
dhn
the problem is i jus realized i dont have the hexagonal type pulley its just the bolt...anyone have any tips?
Old Oct 6, 2007 | 07:42 AM
dhn's Avatar
dhn
uppp
Old Oct 6, 2007 | 08:07 AM
bpkmrtoes's Avatar
Default Re: (dhn)
all i use is a rag and chain pipe wrench with breaker/cheater bar.
Old Oct 6, 2007 | 09:16 AM
`chrisb's Avatar
Default Re: (bpkmrtoes)
I used a torque wrench to get the pully off or whatever or to loosen it rather... im marked the timing belt up top of the motor and down the bottom so i would know where the timing was so i didnt have to time it again ..
Old Oct 6, 2007 | 09:17 AM
dhn's Avatar
dhn
im jus gonna get a strap wrench and put it on the pulley then use a breaker bar
Old Oct 7, 2007 | 06:58 AM
circuitEG6's Avatar
Default Re: (`chrisb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb &raquo;</TD></TR><TR><TD CLASS="quote">I used a torque wrench to get the pully off or whatever or to loosen it rather... im marked the timing belt up top of the motor and down the bottom so i would know where the timing was so i didnt have to time it again .. </TD></TR></TABLE>
NEVER EVER use a torque wrench to break ANYTHING LOOSE!!!!!!!!! EVER!!! it ***** them up there used to tighten **** down to specific torque specs!!!
Old Oct 7, 2007 | 07:06 AM
B16Chaser's Avatar
i had to use a torch and an impact gun to get my bolt loose,,,i dont recomend that unless your doing a complete rebuild though,,,after you get it out use anti seize before you put it back in
Old Oct 7, 2007 | 08:48 AM
dhn's Avatar
dhn
i CANNOT get this bolt off..i guess i have to jam something in the flywheel
Old Oct 9, 2007 | 12:19 PM
circuitEG6's Avatar
Default Re: (dhn)
do you have access to an 1/2 in impact gun and compressor? that will take it off!! they usually max at 600ft/lb of torque!! if not just try rust=off or even brake fluid works great for me just dont get it in your eyes lol
ej1252
Jan 16, 2010 10:22 AM
bOOsTiNSoHcVtEc
Aug 4, 2005 09:29 AM
aaaabbbb
Oct 5, 2004 03:02 PM
YellowCivicE
Jul 12, 2004 06:57 AM
