How would I hook up an amp to a stock cd player (98 civic dx)? Thanks
Very carefully...
You need a LOC (Line Out Converter). This taps into your speaker wires (usually rear) and converts them into RCA. Amp kit, etc still applies.
Ive used the NE-7V with good results.
http://www.autosound2000.com/
There are a few things you can do.
What is the amp going to drive?
What is the make and model of the amp?
Are you going to use more then one amp?
Answer the above and I can give you the options available.
94
94
"You need a LOC (Line Out Converter). This taps into your speaker wires (usually rear) and converts them into RCA. Amp kit, etc still applies".
__________________________________________________
Yup!
Yup!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow29485 »</TD></TR><TR><TD CLASS="quote">"You need a LOC (Line Out Converter). This taps into your speaker wires (usually rear) and converts them into RCA. Amp kit, etc still applies".
Yup!
</TD></TR></TABLE>What if the amp has speaker level inputs, do you still need the LOC?
What if he is replacing all the speakers and adding amplification to them and subs, will a LOC still do the job properly?
Although a LOC, amp and amp kit may be all he needs, your only assuming it is.
94
Yup!
</TD></TR></TABLE>What if the amp has speaker level inputs, do you still need the LOC?What if he is replacing all the speakers and adding amplification to them and subs, will a LOC still do the job properly?
94
liquid_imagination
Audio / Security / Video
Oct 4, 2008 07:41 AM
PaChiLa Leader
Jun 16, 2008 11:23 AM
