bspt to npt adapter, need it?
Old Oct 5, 2007 | 09:14 AM
climb_on's Avatar
Default bspt to npt adapter, need it?
just got my blox sandwhich adapter from blox to use with my stock oil pressure sensor.
now to recap the sensor is bspt thread and the sandwhich adapter is npt thread.
now how close are the two threads because my sensor seems to screw right into it no problem, question is will it seal properly?
or is my best getting the bspt to npt adapter?
thanks H-T
Old Oct 5, 2007 | 10:40 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Well you got lucky and I'm guessing your fittings are either 1/2" or 3/4", because those are the only 2 sizes that have the same thread pitch between NPT and BSPT. NPT is National Pipe Thread tapered, which means the diameter of the threads tapers down towards the end, which makes it easier to attach pieces to each other. BSPT is British Standard Pipe Thread, which can be tapered or not tapered.
My guess is it will seal just fine if you use some teflon tape thread sealant on it.
Stoich EG2
Jun 9, 2006 09:34 PM
RACEPAK
Dec 31, 2004 06:04 PM
integra-modder
Nov 12, 2003 05:29 PM
cjb80
Jan 29, 2003 02:37 AM
_Endless_
Oct 7, 2002 09:29 PM
