Reseting ECU...
Old Oct 5, 2007 | 08:31 AM
EFstyle's Avatar
Default Reseting ECU...
alright so i searched and found many answers but im wondering wich way is best...
Old Oct 5, 2007 | 08:47 AM
EL Vap133's Avatar
Default Re: Reseting ECU... (EFstyle)
Disconnect the battery for a while, reconnect.
Old Oct 5, 2007 | 09:13 AM
Fezzie's Avatar
Default Re: Reseting ECU... (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Disconnect the battery for a while, reconnect. </TD></TR></TABLE>
Old Oct 5, 2007 | 10:12 AM
thevtecnician's Avatar
Default Re: Reseting ECU... (Fezzie)
You take the hazard fuse out for ten seconds. Its found in the underhood fusebox on the passenger side shock tower.
Old Oct 5, 2007 | 01:38 PM
STREETWERKZ's Avatar
i usually pull the ECU fuse under the hood. that way i dont need to reset the radio stations.
Old Oct 5, 2007 | 10:21 PM
jdm_ef9_b16's Avatar
i usually pull both. unhooking the battery and then hooking it back up and reseting everything sucks
uscivicmc
Nov 7, 2005 07:26 PM
Pearlude
Nov 14, 2004 06:41 PM
trooper0641
Jan 2, 2004 10:09 PM
SleepnCiViC
Dec 5, 2003 02:56 PM
sleepyhamsterlx
Nov 26, 2003 06:52 PM
