NEED HELP, GSR in 92 hatch what wires are o2 sensor going to comp?? (searched)
Old Oct 5, 2007 | 06:19 AM
20_sec.hatch's Avatar
Default NEED HELP, GSR in 92 hatch what wires are o2 sensor going to comp?? (searched)
Hello this is my delema I have a 92 civic hatch and I put a gsr swap in it and the o2 sensor is not wired up need to know which wires they are. Does anyone have a diagram, I know someone here has done the swap and knows which wires they are.
Old Oct 5, 2007 | 06:55 AM
Kegan's Avatar
Do you not have the factory plug? If not, why?
Old Oct 5, 2007 | 07:01 AM
Ron454321's Avatar
What wire harness are you using?
Old Oct 5, 2007 | 07:29 AM
Sleepy_Red_hatch's Avatar
Default Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 &raquo;</TD></TR><TR><TD CLASS="quote">What wire harness are you using?</TD></TR></TABLE>
i think he needs to know where to wire up the secondary 02 sensor since his 92 only had one, and GSR motors have two....ill be he's trying to run it obd1......but failing none the less, if this is still unaswered tonight ill asnwer it, i cant look stuff up too much at work
gl!
Old Oct 5, 2007 | 08:03 AM
I am running a p72 with stock civic under dash harness, when i got the swap it was in another civic and the o2 sensor was spliced into 2 wires going to the comp but i dont know which 2
yes it is obd1
Old Oct 5, 2007 | 08:50 AM
Ron454321's Avatar
This link has the ECU pinout for the P72
http://www.phearable.net/tech/wiring/pinouts2.htm
I'm putting that one in my favorites
Modified by Ron454321 at 10:05 AM 10/5/2007
Old Oct 7, 2007 | 06:51 PM
ghettochild's Avatar
its not hard if you want me to help you with it i will
Old Oct 7, 2007 | 07:24 PM
Hybrid96EK's Avatar
Default Re: (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
i think he needs to know where to wire up the secondary 02 sensor since his 92 only had one, and GSR motors have two..</TD></TR></TABLE>
Only the OBD2 ones use two O2 sensors... Just like any other swap..
luvmihatch
Mar 6, 2008 11:35 AM
RoB316
Jul 20, 2007 04:58 PM
ChrisDaun
Feb 12, 2004 04:25 AM
SOUNDEFFECTS
Jan 23, 2003 12:22 PM
