electrical questionnn!!!
Old Oct 4, 2007 | 07:00 PM
JdM_RACeR07's Avatar
Default electrical questionnn!!!
okay so i just did a full wire tuck...finished up about an hour ago then i went to go make sure the lights and everything worked and only a few do...
the driving lights work but only i light on each side....the driver side front bumber light doesnt work....
turn signal only works on passenger side annddddd...
i have no tail lights....brake lights work fine but no tail lights
ive checked every fuse and they are all good
wires all have good connections too...
WTF could be the problem???
Old Oct 4, 2007 | 07:01 PM
The_Undertaker's Avatar
75.168.105.221
Did you check for grounds?
Old Oct 4, 2007 | 07:05 PM
Default Re: (The_Undertaker)
yeah on the driver side i mounted the ground behind the fender and its pretty tight and clean and on the passenger side i did the same
except on the passenger side i grounded both of the grounds to the same bolt...could that be a problem
Old Oct 4, 2007 | 07:23 PM
75.168.105.221
Where exactly did you mount the ground behind the fender? On the outside frame or inside the firewall. It does not matter if all grounds are together. Current is trying to find home so if one ground is available all current will go to that ground to complete circuit. Are the lights dimmed or totally off?
Old Oct 4, 2007 | 07:35 PM
yeah on the outside of the frame is where they are...
they are all tight and everything
but one thing i dont get is how the tail lights wouldnt work if they run on a separate harness
99ej6gsr
37
Nov 16, 2010 11:04 AM
your local ricer
May 6, 2010 04:09 PM
2.2accord
Mar 22, 2009 03:52 PM
Kamikaze
Jul 20, 2006 11:55 AM
