Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Low Compression Pistons!?!
Old Oct 4, 2007 | 05:21 PM
RICO_'s Avatar
NO MERCY!
Default Low Compression Pistons!?!
http://www.corsportusa.com/sto...=1875
Just noticed these on corsport and was wondering what kind of benefits these will have in conjunction with a T/C or S/C setup. Is this a mod that can be used by itself or will it result in power loss?
Old Oct 4, 2007 | 05:36 PM
MessGSR's Avatar
Default Re: Low Compression Pistons!?! (RICO_)
they are good for Turbo and supercharger beucase it allows you to run more boost, with less chance of breaking...but if i was boosting i would get rods also
Old Oct 4, 2007 | 06:37 PM
fg2si!kid's Avatar
New User
Default Re: Low Compression Pistons!?! (MessGSR)
^ what he said
Old Oct 4, 2007 | 06:58 PM
fg2si!kid's Avatar
New User
Default Re: Low Compression Pistons!?! (fg2si!kid)
also i noticed that on corsport it states that the JE piston requires no "deburring or preparation" thats not true i work for brad anderson enterprises and we use JE pistons in our 3000 hp pro mod drag cars and i have had to deburr them not alot but i have had too
Old Oct 4, 2007 | 08:12 PM
FG_2_KILLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR &raquo;</TD></TR><TR><TD CLASS="quote">they are good for Turbo and supercharger beucase it allows you to run more boost, with less chance of breaking...but if i was boosting i would get rods also </TD></TR></TABLE>
well said!!
Old Oct 5, 2007 | 11:31 AM
Hellzcivic's Avatar
You can run more boost without fear of breaking a rod. If you’re not boosted, the benefit would be the ability to run a lower octane fuel without fear of detonation. With 9:1 could safely run a minimum octane of 87.
The problem with running something like this is the same with everything else with these cars. Fuel tuning. The car is tuned for higher compression. I would think you would need a reflash or stand alone fuel management to correct the fuel mixture.
Old Oct 5, 2007 | 04:30 PM
RICO_'s Avatar
NO MERCY!
Default Re: Low Compression Pistons!?! (Hellzcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellzcivic &raquo;</TD></TR><TR><TD CLASS="quote">You can run more boost without fear of breaking a rod. If you’re not boosted, the benefit would be the ability to run a lower octane fuel without fear of detonation. With 9:1 could safely run a minimum octane of 87.
Exactly the two answers I was looking for. Thanx guys.
bseriesEF
10
Nov 13, 2006 04:37 PM
Dasani
Jul 5, 2006 12:26 PM
ochsy03
Mar 12, 2005 08:33 PM
legoman
Jan 25, 2005 01:49 PM
EM2MoNsTeR
Sep 15, 2003 02:06 PM
