Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Axle Nut
Old Oct 4, 2007 | 03:30 PM
MartyPike's Avatar
Default Axle Nut
When the axle nut is removed, should the axle slide out of the hub?
Old Oct 8, 2007 | 08:02 AM
toyomatt84's Avatar
Sanji
Default Re: Axle Nut (MartyPike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MartyPike &raquo;</TD></TR><TR><TD CLASS="quote">When the axle nut is removed, should the axle slide out of the hub?</TD></TR></TABLE>
You remove the lower ball joint or the McPherson strut mounts? You have to release the hub from the suspension in order to get enough free movement on the axle to pull it from the transmission.
SR20S13
Oct 14, 2011 05:01 AM
DarkBB4
Apr 22, 2007 09:29 PM
madmanmulligan
10
Aug 25, 2006 03:35 PM
ahloung
15
Mar 14, 2006 11:52 AM
Feb 19, 2004 08:54 PM
