'clunk' noise in rear end
Old Oct 4, 2007 | 02:50 PM
jjr_99prelude's Avatar
Default 'clunk' noise in rear end
theres a very loud clunk noise coming from my rear right tire whenever i drive over a decent size bump etc. i had a blown out shock but i replaced that and the spring, but now it sounds the same if not worse. any suggestions???
Old Oct 4, 2007 | 03:58 PM
dtec's Avatar
Default Re: 'clunk' noise in rear end (jjr_99prelude)
shock knock?
Old Oct 4, 2007 | 04:47 PM
zsudz922's Avatar
Default Re: 'clunk' noise in rear end (dtec)
look under the rear-end of the car and make sure your rear sway bar mounts are still attached to the chassis.
my car made the same kind of noise but at the rear left side. i looked under the car and the rear sway bar mount on that side had rusted out and fell.
Old Oct 4, 2007 | 07:30 PM
lude98SH's Avatar
Default Re: 'clunk' noise in rear end (zsudz922)
check the sway bar.... and do a bounce test on the shocks. Personally i would remove the sway bar and drive around, if the sound goes away theres your problem. Otherwish test further
Old Oct 4, 2007 | 07:34 PM
Ralleh's Avatar
I noticed the same thing in my right rear side...weird. I'll have to take a look tomorrow.
Old Oct 4, 2007 | 08:12 PM
jmai86's Avatar
Default Re: (Ralleh)
Ha I have the exact same situation.
I've tried everything, nothing seems to work. Even got new endlinks, etc.
Could it be a loaded swaybar?
Old Oct 4, 2007 | 08:20 PM
prelude_h22vtec's Avatar
also check the upper control arm mounting points(anchors) and your balljoints.
Old Oct 5, 2007 | 12:18 PM
Default Re: (prelude_h22vtec)
thanks guys, i'll check all of that soon. if i find out what it is, i'll be sure to repost this w/the answer.
Old Oct 5, 2007 | 01:43 PM
v4lu3s's Avatar
RTFM
on my wifes lude the bolts holding the trailing arm to the body LOOKED fine but were loose.
Old Oct 6, 2007 | 05:25 AM
E-Money's Avatar
Default Re: (v4lu3s)
leave the sway bar on. check the endlinks.
Old Oct 6, 2007 | 09:14 AM
Cottonwoodz's Avatar
Default Re: (E-Money)
+1 on the endlinks
Old Oct 6, 2007 | 09:38 AM
E-Money's Avatar
Default Re: (Cottonwoodz)
actually replacing my sway bar with new ones right now. had to take the bar to my buddies shop to zing the old ones off.
Old Oct 6, 2007 | 11:00 AM
manbearpig's Avatar
My sway bar broke last week, made a hell of a clunking sound. Pulled the one off my parts car, and I'm good.
Old Oct 6, 2007 | 01:56 PM
jmai86's Avatar
Default Re: (mang.)
Might not be the endlinks, I just replaced mine with new oem ones.
Check the components all around your suspension to see if anything is hitting each other. On mine there is a small dent on the muffler piping right underneath the LCA. Dunno if it was like that when I got it or not, seems to be enough clearance.
Old Oct 15, 2007 | 03:43 PM
Default Re: (jmai86)
idk, i checked over everything and everthing seems to be solid. whats a good way to check the balljoints??? maybe thats a possibility?
Old Oct 15, 2007 | 09:28 PM
B.J.'s Avatar
that sucks bump
Old Oct 16, 2007 | 02:53 PM
E-Money's Avatar
Default Re: 'clunk' noise in rear end (B.J.)
you did not mention if you were dropped or not
Old Oct 16, 2007 | 05:00 PM
Default Re: 'clunk' noise in rear end (E-Money)
yes, it is dropped. but i don't understand why it would just be making the noise on one side??? and from looking at the fenders on the inside etc, it doesn't look like its hitting/botteming out. i did notice that the rubber ring(where the upper part of the spring fits into)was hanging down on the old set up. but now its firmly set in there. could there be some damage done from the old set up???
Old Oct 16, 2007 | 07:45 PM
E-Money's Avatar
my koni/eibach pro setup is still making a noise with the new oem endlinks...
Old Oct 17, 2007 | 05:30 AM
fzr's Avatar
fzr
http://www.hondarevolutions.com/lude/prelshok.htm
Wish I'd known about this when I still had my 4th gen.
Old Oct 17, 2007 | 11:39 AM
E-Money's Avatar
Default Re: 'clunk' noise in rear end (fzr)
im just thinking in my head how does one cure this with the vehicle weight still loaded? i cant even fit a hand in the wheel well.
Old Oct 17, 2007 | 05:36 PM
thanks for this, i'm gonna get on this ASAP. cuz i really think this is the problem.
Old Oct 17, 2007 | 06:53 PM
LudeBehavi0r's Avatar
Thanks for that link man. Im glad someone was able to shed some light on this because mine was doin this a little b4 i put the new springs on it.
Ethylment
Honda CR-V & Element
Mar 8, 2015 10:39 AM
jvue
May 28, 2013 09:19 AM
vjsarthy
Jan 7, 2009 03:53 PM
parrot1986
Oct 16, 2008 09:03 PM
7808
Dec 30, 2007 05:07 PM
