4G63 cam angle sensor on a H22A?
Old Oct 4, 2007 | 02:47 PM
twilightprotege's Avatar
Default 4G63 cam angle sensor on a H22A?
I've heard that guys swap the dizzy off the H22A for a mits 4G63 cam angle sensor when they want to go away from the dizzy setup to individual coils or a wasted spark setup. then they use an ems setup for a mits 4G63.
does anyone know this? can anyone provide any information or confirm this? thanks.
Old Oct 4, 2007 | 06:08 PM
alterdcreations's Avatar
Default Re: 4G63 cam angle sensor on a H22A? (twilightprotege)
88-91 b20 prelude sensor
Old Oct 4, 2007 | 08:47 PM
any truth to the 4g63 sensor? reason being is i'd prefer to use the mits sensor as a good friend of mine is doing a 4g63 engine and the more things we can get the same (ie ems) the better.
unless the b20 sensor is the same as the 4g63 sensor?????
Old Oct 11, 2007 | 02:03 PM
can anyone help???
Old Oct 11, 2007 | 04:18 PM
mgags7's Avatar
You would have more luck posting this in the tech or allmotor forums. I've never done it. You can set up a rig to use stock sensors and take all the rest of the crap outta the dist though...
Old Oct 11, 2007 | 04:52 PM
i'll try posting there, thanks.
i've already taken the stock dizzy completely appart. my ems only requires the inner and outter cogs for it to work.
Old Oct 11, 2007 | 05:24 PM
mgags7's Avatar
Then why even mess w/it?
Just leave the pickups in there, and run your wastespark system.
User "Rosko" made a sizzick little distributor cap thingy to run a similar setup, look for his h23vtec build thread for some pics. If you pm him, he'll help you out, hes a great guy
Old Oct 11, 2007 | 06:50 PM
because the 4g63 cas is far smaller and more visually appealing than the huge h22a thing
will check out the build thread
Old Oct 12, 2007 | 03:52 AM
spoolinlude's Avatar
I live under a rock
Default Re: (twilightprotege)
get Tony's cam trigger..... by far the best option, but why are you going distibutorless if your car isn't turbo or super high compression, there really isn't much need.
http://www.t1racedevelopment.com/
Old Oct 12, 2007 | 04:05 AM
bluedlude's Avatar
Default Re: (spoolinlude)
i agree with matt, i think Rosko's housing is the best bet if he'll fab up another one.
although the price of an EMS just for the sake of switching to coils isnt really worth it.
Old Oct 14, 2007 | 05:13 PM
my engine will be making 800whp(ish), gt40 turbo, methanol etc etc
Old Oct 14, 2007 | 05:19 PM
dagle's Avatar
lol really 800whp... for some reason i really dont want to believe it..
Old Oct 14, 2007 | 05:34 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twilightprotege &raquo;</TD></TR><TR><TD CLASS="quote">my engine will be making 800whp(ish), gt40 turbo, methanol etc etc</TD></TR></TABLE>
good luck
Old Oct 14, 2007 | 06:14 PM
purpose built drag car helps that equation
2009HondaAccord
Feb 18, 2018 06:41 PM
kissifur
Jun 20, 2014 12:45 PM
Kane666
Aug 26, 2012 03:42 PM
demo024
Honda CR-V & Element
Jan 31, 2011 12:03 AM
