GSR SWAP
Old Oct 4, 2007 | 01:44 PM
MINIREX88's Avatar
Default GSR SWAP
RUN INTO A LITTLE PROBLEM OVER THE WEEKEND, WHILE PUTTING MY NEW GSR SWAP (B17) INTO MY 88 CRX SI.
THE ALTERNATOR PULLEY IS RUBBING ON THE FIREWALL, WHEN THE FRONT END IS FLEXING, LIKE GOING OVER SPEED BUMP. I BEAT IT IN LIKE YOUR SUPPOSE TO, BUT I GUESS ITS NOT GOOD ENOUGH. SO IM ASKING IS THERE ANYWAY TO TO BEAT THAT IN SOMEMORE WITH OUT PULLING THE MOTOR BACK OUT AGAIN
THANKS
Old Oct 4, 2007 | 01:50 PM
garageEF's Avatar
Default Re: GSR SWAP (MINIREX88)
take the motor out. make the dent bigger. /thread
Old Oct 4, 2007 | 04:21 PM
The_Undertaker's Avatar
75.168.105.221
No, we do not beat on our b series. For you expect it to be rebuild in 6 months. As for the dent for the alternator clearance obtain a small sledge. Remove alternator and bracket and intake manifold and have a cheater pipe with the sledge hammer with both hands and bang the thing down to a perfect bash . This WILL be a perfect alternator clearance. Trust me this was done by me. As for other they have there long ways.
Old Oct 4, 2007 | 04:28 PM
highflyinhonda's Avatar
Just pull the motor back out. Its not like thats hard. You can be a lot more accurate and comfortable swinging a hammer without it in there.
Old Oct 5, 2007 | 08:11 AM
GSR_Hatch12's Avatar
I agree pull the motor and do it.
Old Oct 5, 2007 | 08:27 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: (The_Undertaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Undertaker &raquo;</TD></TR><TR><TD CLASS="quote">No, we do not beat on our b series. For you expect it to be rebuild in 6 months. As for the dent for the alternator clearance obtain a small sledge. Remove alternator and bracket and intake manifold and have a cheater pipe with the sledge hammer with both hands and bang the thing down to a perfect bash . This WILL be a perfect alternator clearance. Trust me this was done by me. As for other they have there long ways.</TD></TR></TABLE>
You can trust what he says too, he's so good at hondas he's had 5 different locations in his info in the last 10 days. Why would it need to be rebuilt? you are better then no one. stop ruining our forum.
Take it out and clear it more, sometimes applying light heat helps the metal be more malleable.
imzjustplayin
May 16, 2008 01:40 PM
ef9robert
20
Sep 25, 2006 12:01 PM
5 Skware
Aug 4, 2003 04:18 PM
5 Skware
Aug 4, 2003 12:31 AM
racecarpete
May 28, 2002 08:22 PM
