Tein Upper Pillowmount Install question
Old Oct 4, 2007 | 01:39 PM
J28S's Avatar
New User
Default Tein Upper Pillowmount Install question
Have a 98 Integra Type R.
Bought the PRH08-31S70 (front & rear) Tein Upper Mounts.
I have a set of Koni shocks and coilovers (H&R springs 1000.250.0700 - 1000SR,2.5"diameter,7" length then again it could be 8"I may have read the # wrong). The inner diminsion of the H&R spring is smaller than the Tein Mount (the little cup where the spring sets in). As a result the spring will not rest against the top of the Tein Mount. Note: the Tein Mount is for a spring ID=70mm (about 2 3/4" opening for the spring...the spring is about 2 1/2"...for the spring to fit, the spring would need to be 2 3/4" ID). Anyone else have this problem? Any ideas on a fix? Thanks
Old Oct 4, 2007 | 02:05 PM
94rs-turbo's Avatar
get different mounts or springs, maybe trim the mount.....
milanoteggy
Suspension & Brakes
12
Sep 10, 2011 04:38 PM
MuGENStyleV6TEC
Apr 2, 2010 11:17 AM
J28S
Suspension & Brakes
Oct 4, 2007 05:57 AM
mr.sedan
Suspension & Brakes
Feb 24, 2006 09:06 PM
donz
Jun 27, 2004 11:45 AM
