integra calipers on civic
https://honda-tech.com/zerothread/1998336
and look under Suspension/Brakes/Steering/Running Gear
theres a lot of info there about brakes
If you look in the civic faq there is a chart with a how to. I believe you would need a dx knuckle with 10.3 in rotors on it. There may be modification needed check the faq. BrakeExpert on here can get you set up right also, he's a great hookup on this stuff, I just got some calipers from him recently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 16v »</TD></TR><TR><TD CLASS="quote">could you tell me, if i set integra TYPE R front calipers on EG6 will my brake improve? will it fit stock civic rotors?</TD></TR></TABLE>
unless you've swapped out the knuckles in your 92-95 honda civic, chances are, you have DX front knuckles. the DX knuckles use a small pad & caliper w/ a 9.4" (19mm) rotor and can be found on 88-00 civic.
ok...itr calipers w/ 10.3" rotors, on DX knuckles: the integra type-r calipers are stamped 17CL15VN. the itr caliper is one of the biggest 1-piston set-up honda makes & uses a pad bigger than 94-00 integra. the itr calipers can be found in junkyards (+97 prelude, vigor, legend, accord, tl, rl, cl, cr-v, odyssey, etc). once you pick up the itr front brakes, you'll need to seperate the caliper & the bracket (stamped 23T or 25T). the bracket will need to be sent to a machine shop where they'll mill 2-3mm (or 1/8") off where the bracket mates with the knuckle. this set-up requires 10.3" rotors which can be sourced in parts stores from any 90-01 integra. *you'll need to upgrade your master cylinder from a 90-91 civic ex since you need more fluid to push the bigger piston.
pm BrakeExpert, he mills 23T brackets & specializes in oem honda brake upgrades
https://honda-tech.com/zerothread?id=1484555
hxtasy
14
Nov 24, 2005 06:41 PM
Patron
13
Oct 30, 2003 02:41 PM
