need advice on what to do to my b18c1 block
Old Oct 4, 2007 | 07:08 AM
spuddo01's Avatar
Default need advice on what to do to my b18c1 block
i recently picked up a gsr block with just the crank. i currently have a second gen jdm b16 in my ej2. im going to use my b16 head still. i want to make around 200 all motor and i do plan to spray. i was thinking i should just get forged rods and pistons and putting type r valve train and cams in my b16 head. my question is what compression should i get since i have a b16 and plan on spraying between a 75-100 shoot of wet. i also plan to do i miled port and polish to the head and port the intake mani and the throttle body. i would like to know what i should do and if any one has a similar set up or know of any and the power it made and track times. (just all motor) thanks
ps let me know if i should get anything else besides type r valve train and cams; or should that be just fine?
Old Oct 6, 2007 | 09:45 AM
spuddo01's Avatar
Default Re: need advice on what to do to my b18c1 block (spuddo01)
Old Oct 6, 2007 | 06:36 PM
cartune network's Avatar
if ur gonna build the gsr i would ditch the spray idea and just go high comp with a good set of cams.
but if u wanna go spray (cheater juice lol) than i would use around an 11.0:1 or an 11.5:1 comp ratio just to keep it nice and safe.
Old Oct 7, 2007 | 05:19 AM
00Red_SiR's Avatar
All Motor Mentor
What you should do is look up people who have actually achieved 200 whp on here and see what they had to do to get there. Once you do that you'll quickly realise that stock type r cams aren't going to get you there and it's not a simple task. I have a decent build for a 1.8 but I will need an SMSP header, better cat-back, head porting, better tune and maybe a bpi velocity stack to hit those numbers at the wheels without spray (and I do spray). Searching will give you the answers you want.
Old Oct 7, 2007 | 01:41 PM
mar778c's Avatar
Community Builder
Community Influencer
See my sig below. That is one of the best build I have ever seen on this board.
Modified by mar778c at 12:11 PM 10/8/2007
Old Oct 8, 2007 | 09:26 AM
spuddo01's Avatar
Default Re: need advice on what to do to my b18c1 block (mar778c)
thanks
Old Oct 8, 2007 | 11:16 AM
lunatics209's Avatar
no need for forged pistons and rods for a 200 horsepower motor. just run stock internals you can achive 250 horsepower with nitrous. i made 254 on a stock ls-vtec.
92 hatchback
Jun 8, 2009 06:05 PM
spoonef
11
Jun 12, 2008 12:58 AM
Unsought Devil
Nov 11, 2006 04:57 PM
Nextelbuddy
15
Jun 2, 2003 10:58 AM
McFly
Sep 17, 2002 09:33 PM
