AutoX all motor setup...need suggestion
Old Oct 4, 2007 | 06:32 AM
EG6wannabe's Avatar
Default b16a all motor setup...need suggestions
hello all...i'm new to VTEC technology and was wondering if u guys could give me some suggestions on building up my B16A engine...
for now...below are my current setup on a Civic EG 92 (hatchback)...
B16A (EG6) Block and Head
CTR Pistons
Stock Tranny
Exedy Semi Racing Clutch Set
Custom SS 4-1 Header
Toda 4.1kg Fly wheel
Sard Fuel Regulator
and Tuned with E-Manage Ultimate
well...i would like to keep my bottom end b16a all the way...any suggestions for my future upgrades...looking forward for power band around 170whp-185whp and a good number of torque if possible...
Modified by EG6wannabe at 11:38 AM 10/4/2007
Old Oct 4, 2007 | 09:08 AM
NirVTEC's Avatar
Default Re: AutoX all motor setup...need suggestion (EG6wannabe)
Maybe check the AutoX/RR forum...
Get the rule book 1st....I know those SOLO2 guys can be whiners about mods.
My friend got Protested for "undercoating" on an STS car.
Old Oct 4, 2007 | 10:39 AM
EG6wannabe's Avatar
Default Re: AutoX all motor setup...need suggestion (::NirVTEC::)
opss...my bad...
thx for the advice though
Old Oct 4, 2007 | 10:49 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6wannabe &raquo;</TD></TR><TR><TD CLASS="quote">opss...my bad...
thx for the advice though </TD></TR></TABLE>
just want you to do it right.....
Old Oct 4, 2007 | 10:50 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: b16a all motor setup...need suggestions (EG6wannabe)
The engine swap already puts you in SM. Even an extreme all motor setup isn't going to make you competitive in that class. EVO's, Sti's, and BMW's pretty much rule that class.
Old Oct 4, 2007 | 10:56 AM
Furyof4's Avatar
A 4.9fd and quaife will make a larger improvement than more power.
Old Oct 4, 2007 | 10:58 AM
NirVTEC's Avatar
Default Re: b16a all motor setup...need suggestions (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">The engine swap already puts you in SM. Even an extreme all motor setup isn't going to make you competitive in that class. EVO's, Sti's, and BMW's pretty much rule that class.</TD></TR></TABLE>
You can be locally competative with it(maybe) but yah, Nationally you won't get very far. Although I know a B18c5 Hatch was in the top5 a couple years ago at Nationals. IIRC he was #4(#1 FWD) behind 3 M3's.
Old Oct 4, 2007 | 10:59 AM
Furyof4's Avatar
Default Re: AutoX all motor setup...need suggestion (Furyof4)
Im getting used to that.
Old Oct 4, 2007 | 11:05 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: b16a all motor setup...need suggestions (::NirVTEC::)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: &raquo;</TD></TR><TR><TD CLASS="quote">
Even then, its going to be highly driver dependent, and the OP kinda sounds like a noob(no offense).
Old Oct 4, 2007 | 11:10 AM
ShaunRR's Avatar
HT White Ops
Community Builder
The point I'm trying to make to the OP is: don't worry about the engine for autox. Concentrate on suspension, and especially your driving technique.
Old Oct 4, 2007 | 12:39 PM
EG6wannabe's Avatar
Default Re: (rochesterricer)
its ok rochesterricer...no hard feelings...i'm a noob in autox btw...no point hiding on that fact...
anyways...thx for the suggestions...yeah...i should concentrate more on suspensions , tranny, chasis, etc...and like u said most importantly my driving techniques...
ohh...sorry once again for posting on the wrong side of the forum...
Modified by EG6wannabe at 2:03 AM 10/5/2007
Old Oct 4, 2007 | 01:43 PM
NirVTEC's Avatar
Even then, its going to be highly driver dependent, and the OP kinda sounds like a noob(no offense).</TD></TR></TABLE>
For sure....
I would just beat the crap out of a stock engine your 1st/2nd year....
Old Oct 4, 2007 | 03:26 PM
soaringchimp's Avatar
I assume you have full exhaust and a highflow cat / test pipe to go with your custom SS header correct?
Old Oct 5, 2007 | 12:52 AM
EG6wannabe's Avatar
Default Re: b16a all motor setup...need suggestions (soaringchimp)
yup...complete...
Old Oct 5, 2007 | 01:31 AM
quicksilver1689's Avatar
i ♥ snails
learn to master driving your setup, suspension is huge, a tighter final drive is good, will you be running race gas? i would get some very aggressive mid range cams with good top end. If piston/valve clearance allows enough room, maybe mill the head and get a little more compression. Just my thoughts, im no expert FYI
good luck
jap-screamer
Mar 13, 2011 03:29 AM
jeffhonda2000
Sep 29, 2006 01:33 AM
C8V6C
Feb 20, 2004 10:53 AM
Xion
Apr 29, 2003 04:05 PM
