Suspension & Brakes Theory, alignment, spring rates....
ES Bushings - Good or Bad? Started putting them on my car today, been reading mix opinions
Old Oct 3, 2007 | 09:25 PM
92integraVTECgsr's Avatar
Default ES Bushings - Good or Bad? Started putting them on my car today, been reading mix opinions
Are these good or bad?
I read and see the part about how the Poly Rear Trailing Arm Bushings Bind up and that worries me..
Who has had a problem with that or and not?
Should I just replace the other bushings or leave my stock old bushings in?
I have a 92 integra gsr.
I was planning on doing Lower LCA Bushings, Lower Shock Mount Bushings, and Sway bar End Links, and Rear Control Arm.
What should I do?
Old Oct 3, 2007 | 09:49 PM
crexer's Avatar
Default Re: ES Bushings - Good or Bad? Started putting them on my car today, been reading mix opinions (92in
i would not use the ES bushings for the trailing arm bushing but you could probably get away with the rest
Old Oct 3, 2007 | 10:01 PM
DavidR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">Are these good or bad?
What should I do?</TD></TR></TABLE>
I would not on any of the above.... Ok, maybe the endlinks.
https://honda-tech.com/zerothread?id=1563815
Rob.
11
Jul 8, 2012 07:13 PM
blk_dc
Suspension & Brakes
Aug 3, 2011 08:11 AM
emr88
Feb 20, 2011 05:29 PM
SE7EN3S
Suspension & Brakes
Sep 16, 2005 09:41 AM
Jays91DXhatch
Apr 27, 2005 08:19 PM
