89 honda civic with b16b engine, still will not start.
Old Oct 3, 2007 | 02:48 PM
leathaldose's Avatar
Default 89 honda civic with b16b engine, still will not start.
I have been told to check the injectors on my car since it will not start, but i can not find them. my car has a carburator looking thing that says programmed fuel injection. i dont see a fuel rail or injectors can some one tell me where to look?
also how hard is it to adjust the timing on this car?
Mine is the one on the right.
Old Oct 3, 2007 | 02:50 PM
Default Re: 89 honda civic with b16b engine, still will not start. (leathaldose)
managed to find an image that looks like what i have under the hood, like previous post mine is on the right.
Old Oct 3, 2007 | 02:52 PM
burtonripply's Avatar
im pretty sure you have 2 injectors. in the pciture on the left you can see the 4 injectors... they are all located on the bottom of the manifold, where it connects tot he engine. in yours, the one on the right, i am pretty sure they are located higher up on the manifold, near the throttle body.
Old Oct 3, 2007 | 02:58 PM
blackmugensivic's Avatar
Default Re: 89 honda civic with b16b engine, still will not start. (burtonripply)
if your manifold looks like the one on the right, you don't have a b16b. a b16b is a 1.6L DOHC VTEC motor out of the Civic Type-R. your injectors are underneath the black plastic air box, in the throttle body. one has a green plug, the other is brown.
Edit- dammit, accidently posted this under my brothers account, i'm actually DarksydeDragun.
Old Oct 3, 2007 | 03:30 PM
Default Re: 89 honda civic with b16b engine, still will not start. (blackmugensivic)
Thanks for the info, are the injectors for this car hard to find or is it something i can pick up at the Local pepboys or Autozone? also thanks for the engine info as well. if its not the b16b i have find the tag again and write it down.
any one have an answer about the timing?
Hyker
Honda CR-V & Element
May 12, 2018 10:18 PM
MikeDTuning
Engine Management and Tuning
10
Jan 6, 2015 09:25 AM
Mike"IAMSLOW"Myers
Aug 15, 2007 08:04 AM
( o )( o )
12
Sep 20, 2005 06:05 PM
Aeka GSR
Jan 28, 2004 05:55 PM
