96 hatch with 2000 si motor, harness question one plug on dash harness?
Old Jun 19, 2002 | 05:05 AM
2dedge's Avatar
Default 96 hatch with 2000 si motor, harness question one plug on dash harness?
The motor is in but have some wiring questions there is one plug which was on the engine harness on the old motor (96) and is on the dash harness of the 2000. Do we have to pull the dash and swap the dash harness or is there an easier way to do it?
Old Jun 19, 2002 | 04:04 PM
Aceman64's Avatar
Default Re: 96 hatch with 2000 si motor, harness question one plug on dash harness? (2dedge)
the easiest thing to do would be to get a harness from a civic EX 96-98 and put it on the engine and it will plug right in. the 99-00 are a little different as you found out.
-Ace
Old Jun 20, 2002 | 10:52 AM
Trey's Avatar
25 Year Member
Default Re: 96 hatch with 2000 si motor, harness question one plug on dash harness? (Aceman64)
Sell the 99-00 Engine harness and ECU. It's a major PITA to get it to work in your car!!!!!
Buy a 96-98 EX harness.
Try and find a 96-97 del Sol ecu (B16a) -good luck.
Get a 96-00 GSR ECU (engine will bog at 4400 prms)
get the OBDI-OBDII ecu harness and OBDI ecu with a New program (Best Bet)
Check out http://www.jspectuning.com/6gen/ for more wiring info...
have fun,
Rheg6
Engine Management and Tuning
Mar 11, 2010 11:20 AM
kphamx
Feb 13, 2008 03:02 PM
oneforce
Apr 11, 2006 02:46 AM
dizzyek
Feb 9, 2006 01:50 PM
prada_2o0o
Mar 14, 2003 07:40 PM
