S/C'd GSR WON'T START!! HELP!!!!!
Old Oct 2, 2007 | 05:28 PM
end005's Avatar
Default S/C'd GSR WON'T START!! HELP!!!!!
delete
Modified by end005 at 6:51 PM 10/6/2007
Old Oct 2, 2007 | 05:35 PM
my_hidden_romance's Avatar
Default Re: S/C'd GSR WON'T START!! HELP!!!!! (end005)
did u take the whole dizzy off?? did u disconnect the wires and put them on wrong? are u getting spark?
Old Oct 2, 2007 | 05:36 PM
end005's Avatar
Default Re: S/C'd GSR WON'T START!! HELP!!!!! (my_hidden_romance)
yeah, I took it completely off. Didn't remove ANY wires.
I am running a msd igntion and all too. Maybe the wiring shorted?
Old Oct 2, 2007 | 06:39 PM
blueDA9's Avatar
sounds like your not getting spark, is ur coil givin juice to ur ignition properly? also how did the oil get into the distributor?
Old Oct 2, 2007 | 07:02 PM
end005's Avatar
Default Re: S/C'd GSR WON'T START!! HELP!!!!! (blueDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueDA9 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your not getting spark, is ur coil givin juice to ur ignition properly? also how did the oil get into the distributor?</TD></TR></TABLE>
That's exactly what I was wondering. How WOULD oil get into my distributor???
Could it be the wiring (tapped to the ignition)?
Could it be that i just have a bad distributor?
Old Oct 2, 2007 | 07:04 PM
Dogginator's Avatar
Daisy... Daisy...
It sounds like the shaft seal in your distributor has failed, hence the oil.
Old Oct 2, 2007 | 07:08 PM
Hulkdon1's Avatar
That sounds like the ignitor unit my friend. An MSD ignition box and coil will prematurely destroy your ignitor. The ignitor is the little brown unit inside the dizzy. You can replace it or get a new dizzy and choose not to use the MSD again. I have had MSD set-ups on several of my cars, and its not worth it. You could have been stranded.
Old Oct 2, 2007 | 07:38 PM
Danziver's Avatar
Default Re: S/C'd GSR WON'T START!! HELP!!!!! (Hulkdon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulkdon1 &raquo;</TD></TR><TR><TD CLASS="quote">That sounds like the ignitor unit my friend.</TD></TR></TABLE>
x2
I had this problem a while back.
Old Oct 3, 2007 | 06:12 AM
end005's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulkdon1 &raquo;</TD></TR><TR><TD CLASS="quote">That sounds like the ignitor unit my friend. An MSD ignition box and coil will prematurely destroy your ignitor. The ignitor is the little brown unit inside the dizzy. You can replace it or get a new dizzy and choose not to use the MSD again. I have had MSD set-ups on several of my cars, and its not worth it. You could have been stranded.</TD></TR></TABLE>
So do you guys think I should just get rid of the msd box and coil? Would it be bad for my setup (Jrsc, 11 psi, stock internals, new pistons/rings/bearings, FMU, STOCK injectors---I'll probably get shot for that one)???
Old Oct 3, 2007 | 06:40 AM
St Jimmy's Avatar
* B A N N E D *
Yes ditch the MSD and get a new ignitor, if you have a helms it will tell you how to check if its bad.
Old Oct 3, 2007 | 06:50 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: S/C'd GSR WON'T START!! HELP!!!!! (St Jimmy)
Fix the oil leak in the distributor as well. That is not helping the electronics.
Old Oct 3, 2007 | 06:52 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by end005 &raquo;</TD></TR><TR><TD CLASS="quote">
I hope you are just waiting to get tuned, right? Surely you dont want to break all these shiny new parts in your motor.
Old Oct 3, 2007 | 07:03 AM
end005's Avatar
Default Re: S/C'd GSR WON'T START!! HELP!!!!! (tweekerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">
I hope you are just waiting to get tuned, right? Surely you dont want to break all these shiny new parts in your motor. </TD></TR></TABLE>
of course. I'm doing the shopping now for a good tuner at a cost effective price. The guys up here charge an arm and a leg!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Fix the oil leak in the distributor as well. That is not helping the electronics.</TD></TR></TABLE>
and how would i go about doing this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Yes ditch the MSD and get a new ignitor, if you have a helms it will tell you how to check if its bad.</TD></TR></TABLE>
I think I may end up just replacing the whole distributor.
Old Oct 3, 2007 | 08:34 AM
Dogginator's Avatar
Daisy... Daisy...
and how would i go about doing this? </TD></TR></TABLE>
[QUOTE=end005]I think I may end up just replacing the whole distributor. /QUOTE]
I have no idea where to obtain the shaft seal.
Old Oct 3, 2007 | 08:44 AM
end005's Avatar
Default Re: S/C'd GSR WON'T START!! HELP!!!!! (Dogginator)
I have no idea where to obtain the shaft seal.</TD></TR></TABLE>
Its cool man. I probably will just replace the whole distributor and eliminate the msd ignition and coils.
Thanks guys!!
Thecargoddess
Jul 3, 2024 07:09 PM
eskimo10
Aug 23, 2007 01:25 PM
jakl315
Feb 24, 2006 04:26 PM
duckming
Jun 5, 2003 05:17 PM
widecoupe
May 12, 2002 11:34 AM
