acl race bear and acl bearing
Old Oct 2, 2007 | 04:17 PM
401B18TEG's Avatar
Default acl race bear and acl bearing
I putted some acl race bearing on my ls vtec but someone told me it not good because the clearance is too tight. it only use for couple run on the track. should i take my motor apart to put acl bearing or keep the race?
Old Oct 2, 2007 | 04:38 PM
IN VTEC's Avatar
Default Re: acl race bear and acl bearing (401B18TEG)
Shouldn't you have known what the oil clearances were when you built the engine?
Old Oct 2, 2007 | 04:42 PM
401B18TEG's Avatar
i cousin put my motor togeather and today someone told me it not recommend for daily driver.
Old Oct 2, 2007 | 05:11 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: (401B18TEG)
ACL's, if I'm not mistaken, are green. They're like the 'average size' or 'middle size' bearings.
I suggest you talk to your cousin and ask him if he measured the journals and bought the appropriate bearings. If he doesnt know, I'd say go ahead and tear down the motor, plastigauge the journals, and get the right bearings.
Old Oct 2, 2007 | 05:33 PM
401B18TEG's Avatar
I think he got it correct. If it was can i use race?
Old Oct 3, 2007 | 04:29 AM
401B18TEG's Avatar
bump
Old Oct 3, 2007 | 01:49 PM
401B18TEG's Avatar
can anyone answer my question. if the spec are correct can i run acl race bearing?
Old Oct 3, 2007 | 06:58 PM
geebs's Avatar
if the specs are right then theres no need to replace them
Old Oct 3, 2007 | 07:29 PM
non-VTEC's Avatar
ACL race bearings are a little looser than the normal ACL bearings.
but without knowing the actual clearances you wont know how it will affect your oil pressure readings.
take the engine apart and do it right the first (second now) time or run a 10w40 or thicker engine oil and pray it holds together.
Old Oct 4, 2007 | 04:23 AM
401B18TEG's Avatar
alright thanks for the contribute
crashsvg
Jan 9, 2014 05:30 AM
adubaz7
Oct 3, 2007 07:49 PM
aleks77
Feb 10, 2007 06:39 PM
7rrivera7
Jan 12, 2007 02:49 PM
