take a look at my intake manifold
Old Oct 2, 2007 | 03:37 PM
95greenlude's Avatar
Default take a look at my intake manifold
there was A LOT of oil in 3/4 IM runners.....is it normal to have THIS much??
Old Oct 2, 2007 | 03:41 PM
bb_one's Avatar
Default Re: take a look at my intake manifold (95greenlude)
Check your PCV valve, looks like it's stuck open.
If you are turbo charged, then check your turbo's oil seals.
It is usually normal with cars with high mileage. All the oil vapors being recirculated back into the IM gets accumulated and you'll have those deposits.
You can prevent this from happening by running a catch can venting to the atmosphere, not back into the IM.
Old Oct 2, 2007 | 03:46 PM
Default Re: take a look at my intake manifold (bb_one)
^i'll check, and no i'm not turbo
Old Oct 2, 2007 | 04:33 PM
SteveoBA8's Avatar
My jdm h22(est 50,000) had a lot of oil in the runners. I bought a catch can and will remove the plenum for a looksee after some miles. But that's when my 94 runs again
Edit: A stuck open pcv valve would seem to make the most sense like matt said.
Modified by SteveoBA8 at 8:11 PM 10/2/2007
Old Oct 3, 2007 | 08:25 AM
CincinnatiBB6's Avatar
if you are a member check in the 5th gen section and it shows how to clean those valves.
Old Oct 3, 2007 | 08:44 AM
mgags7's Avatar
I used to have a catch can on mine, and the vial, roughly 2 ounces, would fill up in about a month.
Now you can understand where some of the h series oil consumption comes from.
Steveo, I didn't say that, lol bb_one did.
But, you can't just leave the catch can open to the atmosphere, you need a vac source to pull air out so you get Postive Crankcase Ventilation instead of just CV.
Old Oct 3, 2007 | 08:50 AM
LukieLuc's Avatar
95greenlude, can you do me a favor and take a picture of the underside of your Intake Manifold, of the IAB solenoid PLS lol
Old Oct 3, 2007 | 08:53 AM
98vtec's Avatar
moderator emeritus
Default Re: take a look at my intake manifold (LukieLuc)
catch can ftw
Old Oct 3, 2007 | 08:57 AM
vinuneuro's Avatar
Default Re: (mgags7)
I wonder if Rosko could add something like this to his product line-up?
Old Oct 3, 2007 | 09:32 AM
i was browsing the FI section and saw the Catch can post about taking a vacuum source to have some flow to the system....i'll probably end up getting one and eliminating the PCV system
after i get a Catch can i'll probably take off the IM and clean it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">95greenlude, can you do me a favor and take a picture of the underside of your Intake Manifold, of the IAB solenoid PLS lol</TD></TR></TABLE>
do you just need a picture of the IAB solenoid? i have an extra IAB plate not in the motor so lmk
Old Oct 3, 2007 | 09:57 AM
LukieLuc's Avatar
I need a pic of the IAB solenoid and the black box next to it. Where the VAC line from my Intake Manifold connects to that black box is broken. I just need a pic, to see what im looking for when i go under the car to pull it out.
heres what is disconnected
Parada
Feb 28, 2007 09:53 AM
user 98292739
Apr 27, 2005 01:26 PM
2fknlo
Mar 14, 2004 07:03 AM
Ri5e
Jan 17, 2003 02:34 PM
90accord1
Dec 13, 2001 06:58 PM
