B20 vtec engine wont run right
hello, my name is Common Sense. Let's start at the beginning:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGKREW »</TD></TR><TR><TD CLASS="quote">i have a B20 vtec engine and and only two pistons are firing. 1 and 4 are firing and 2 and 3 arnt. it isnt losing compresion cuz i checked it and every thing is good. and it aint the dizzy cuz my dizzy is good and i tryd my homies dizzy off his running car. could some one help me out it would help alot . THANKS! </TD></TR></TABLE>
Now that we know the problem, and what you've tried to fix it... let's move on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGKREW »</TD></TR><TR><TD CLASS="quote">ya no spark</TD></TR></TABLE>
Answered your own question there champ.
If you REALLY did try your friends distributor off of his running car, and his didn't work... then the only other link between cylinders 2 and 3 is the spark plug cables; and cap/rotor. (which I'm assuming you changed out as well)
$.02
-jonathan
$.02
-jonathan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune »</TD></TR><TR><TD CLASS="quote">take it to someone that might even have a clue to troubleshooting
go through these steps, you have already done some of them. the basics are fuel and spark right?, so you have checked for spark, from what i picked up 1 and 4 have spark and 2 and 3 dont, lets leave that alone for now. fuel, to check just take all your plug wires off and crank the engine, then take the plugs out one by one and smell for fuel like Kevinz said. if you have fuel on all four cyclinder and still have spark on only two of them after changing out companants like wires, dizzy, etc. then you have to go up the "spark tree" , have you changed/customized your harness, if so re-check all of those areas, if all that is good then you should check your ECU. other things might be timing, though i dought it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune »</TD></TR><TR><TD CLASS="quote">take it to someone that might even have a clue to troubleshooting </TD></TR></TABLE>
