ls-vtec VS b20-vtec as daily driver > best ?
got GSR rod knock > should i go w/ "STOCK" LS-vtec OR b20-vtec as replacement ?
pls advise w/ staying " S T O C K " block in mind > i cant afford to go all out > no $$$
stock block Ls-vtec SUCKS (if you put pistons then its great but a stock LS block
)...... go with the Stock B20 block with your GSR head!
i wouldn't go as far as saying a stock ls/vtec "sucks" with a stock block...
but the B20 block will offer you more torque, it would be my choice. If you're planning on working up to the FI, then you would probably be happier in the long run with the LS block.
-jonathan
-jonathan
You can do lsvtec and drop in some p30 pistons, they are stock and cheap to find. But if you want a bottom end you dont want to touch I would do a b20 b/c Im sure the TQ even with the low compression is better than my b16.
-Edit. Dont forget to throw on a vtec oil pump regardless of which block you choose along with corresponding water pump and timing belt.
you want to stay with the ls crank and rods. Just drop in some pr3s pistons. Ls crank + rod = longer stroke. but if your gotta choose between an completely stock ls block or b20 block, my "opinion" is the ls. less torque, but more relaible for street driven. AND for american.Graffiti, why an "vtec oil pump", assuming you know what your talking about. Do you know what your talking about? if not, then stay quiet, stop giving bad advices.
OP start here.
https://honda-tech.com/zerothread?id=1676914
Whats your budget? LS would be better in my opinion if your on a really thight budget. As stated before you can reuse factory pistons, as oppose to having to buy aftermarket with the B20.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls-vtec-delsol »</TD></TR><TR><TD CLASS="quote"> AND for american.Graffiti, why an "vtec oil pump", assuming you know what your talking about. Do you know what your talking about? if not, then stay quiet, stop giving bad advices. </TD></TR></TABLE>
Seriously using a vtec oil pump is not bad advice, lol. You just have to use the correct belt , being a vtec belt.
do you know what you're talking about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">fyi, all 96-01 b series oil pumps are exactly the same.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chippy »</TD></TR><TR><TD CLASS="quote">part numbers are different on the type R and GSR
itr = 15100-P72-A01
gsr = 15100-P72-A01
http://www.sonsacuraparts.com
</TD></TR></TABLE>itr = 15100-P72-A01
gsr = 15100-P72-A01
I cast my vote for the GSR. I had a LS in my first hatch, and it was fun but I wanted something that can rev higher so I got the GSR. It's the best of both worlds, stock 8k redline and good fifth gear torque, nothing but fun for me. B20V is a good contender , if built the right way, as the reliability will be there and you'll be making more power easier (if we're talking NA) but you can't beat the reliability of a factory VTEC motor. Also did I mention my motors already put together ? Haha jk
VNTEC
Dec 20, 2005 12:55 PM
you're about 9 years to late.
