HELP INTEGRA PROS
ok i have a 99 gsr, with fully upgraded suspension, from coilovers to bushing to bars to performance mounts to everything. Okay
However, i have a problem. When I drive at a slow speed, i hear some type of movement, as if something is loose. It makes like a clunking type of sound and then goes away. Its only at slow speed, like below 10 mph. At high speed this car is a beast.
I checked the suspension and everything is really tight and looks like it can withhold some high speed.
What do you think it can be.
Oh and by the way, the noise comes from the front driver side, like where the upper arms are or the motor mount area.
But its weird because the motor sits super tight and does not move. Nor does the upper arm( i have skunk 2 camber kit upper arms)
Any help will be appreciated. Thank you
no. it makes like one clunk and goes away. it only happens at extremely slow speeds. it happens when i go straight or turn, but its at slow speed only. i checked the axles, they seem pretty solid. dam something so smalll is pissing me off.
dudeomega2000
Apr 24, 2008 05:22 PM
J.nguyen
Suspension & Brakes
30
Sep 26, 2006 12:39 PM
Snapspinnr
Oct 30, 2002 10:41 AM
