Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
HID's not wrking...
Old Oct 1, 2007 | 07:54 PM
bikerballrEM2's Avatar
Default HID's not wrking...
i got an h4 plug an play kit.... everythings connected... i also upped the fuses from 15 to 20a an the low beams dont wrk but the high beams do... everything connected like it should be...... any ideas??
Old Oct 1, 2007 | 08:19 PM
toyomatt84's Avatar
Sanji
What kit did you buy?
You'll need to be more specific when asking questions.
Old Oct 1, 2007 | 08:23 PM
Default Re: (toyomatt84)
brightstar tw xenon.... theyr capable of high an low with 5000k bulbs
Old Oct 2, 2007 | 04:37 AM
imroadk1ll's Avatar
did u touch the bulbs with ur hands like a lot of people nowdays are doing. if not then try look at the bulbs if they looked burnt.
Old Oct 2, 2007 | 08:46 AM
Default Re: (imroadk1ll)
no i didnt touch the bulbs.... low an high beam wrks on my friends ek but not my 03 em2...
Old Oct 2, 2007 | 09:32 AM
devani's Avatar
Default Re: (bikerballrEM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bikerballrEM2 &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt touch the bulbs.... low an high beam wrks on my friends ek but not my 03 em2...</TD></TR></TABLE>
There's your answer....your car is EM2 his car is EK...
EM2 ground switched...EK positive switched...
Old Oct 2, 2007 | 11:57 AM
lifes_simple's Avatar
Default Re: (devani)
i did my HIDS a different way. you should have a ballast which has two connections, 1. should be from the ballast connecting to the bulb and 2. should be the ballast conncted and wired to your positive and negetive stock bulb wire. I cut my old connections so that all that was left was the red and black. i then connected those two wires to the red and black wire from the ballast. after that, it should work.
Old Oct 3, 2007 | 03:16 AM
imroadk1ll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devani &raquo;</TD></TR><TR><TD CLASS="quote">
EM2 ground switched...EK positive switched...</TD></TR></TABLE>
wow right thurr is the problem.
Old Oct 3, 2007 | 11:13 AM
but i thought 9003 an h4 were the same??... well is it possible to get the hid's to wrk?? if so has anyone done it??
Old Oct 3, 2007 | 11:46 AM
devani's Avatar
http://www.hidplanet.com/forum...=6612
Read more about the harness and ground switched and positive switched..
Old Oct 3, 2007 | 12:03 PM
this is gnna be a headache isnt it??...lol
Old Oct 3, 2007 | 12:05 PM
thanks for the info.....this is gnna be a headache isnt it??...lol
Old Oct 3, 2007 | 12:16 PM
devani's Avatar
no problem....it should not be a headache....just let us know when you are finished and post pics
Old Oct 3, 2007 | 12:20 PM
i def will..... thanks for the help guys....
dpacheco
21
Feb 1, 2010 11:26 PM
Jet Black
10
Apr 19, 2007 03:09 AM
jweezy225
Aug 9, 2004 05:43 PM
MugenHonda
Nov 17, 2003 06:30 AM
AnNiMosSiTY
Sep 9, 2003 11:08 PM
