Cats for stock exhaust?
Old Oct 1, 2007 | 05:51 PM
VR4ownzU's Avatar
Default Cats for stock exhaust?
Are there any cats out there that bolt up to the stock exhaust system that aren't OEM? I'm having a hard time finding a used stock ITR CAT. Looking for other alternatives...
Old Oct 1, 2007 | 05:55 PM
get RIGHT's Avatar
Default Re: Cats for stock exhaust? (VR4ownzU)
SMSP and Carsound, I believe make them.
Old Oct 2, 2007 | 07:45 AM
white rocket's Avatar
^^^^correct. Even Vibrant has hi-flow cats. That's what I run. Shouldn't be hard to find a cat and get the proper flanges and have a muffler shop weld it all together for you. <---------**/end run on sentnece>**
Old Oct 2, 2007 | 03:40 PM
VR4ownzU's Avatar
Default Re: (white rocket)
I just want a stock CAT ASAP.
Old Oct 2, 2007 | 03:48 PM
Comp97GSR's Avatar
Default Re: (VR4ownzU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VR4ownzU &raquo;</TD></TR><TR><TD CLASS="quote">I just want a stock CAT ASAP.</TD></TR></TABLE>
I have an orange tabby you can have. He is slightly defective but in good shape.
Old Oct 2, 2007 | 04:17 PM
get RIGHT's Avatar
Default Re: (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">
I have an orange tabby you can have. He is slightly defective but in good shape. </TD></TR></TABLE>
awwwwww. Pics please.
Old Oct 2, 2007 | 04:18 PM
JjuuN R's Avatar
Default Re: (get RIGHT)
That's not very nice John.
Old Oct 2, 2007 | 04:22 PM
get RIGHT's Avatar
Default Re: (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">That's not very nice John. </TD></TR></TABLE>
Did you used to own said cat?
Old Oct 2, 2007 | 05:50 PM
JjuuN R's Avatar
No, heh.
Old Oct 3, 2007 | 10:42 AM
dwolsten's Avatar
I have a mildly retarded russian blue...
Old Oct 3, 2007 | 12:27 PM
VR4ownzU's Avatar
Default Re: (dwolsten)
I need a CAT Converter....is that more specific?
Old Oct 3, 2007 | 01:13 PM
get RIGHT's Avatar
Default Re: Cats for stock exhaust? (get RIGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">SMSP and Carsound</TD></TR></TABLE>
Old Oct 3, 2007 | 01:53 PM
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">SMSP and Carsound, I believe make them.</TD></TR></TABLE>
SMSP uses the Magna Flow Carsound cat.
Old Oct 3, 2007 | 01:59 PM
ac_attak's Avatar
Just get a carsound cat for $50, and have a shop weld it in. Thats the cheapest way to go and is just as good as the bolt on smsp.
Old Oct 3, 2007 | 02:20 PM
dwolsten's Avatar
Default Re: Cats for stock exhaust? (ac_attak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">Just get a carsound cat for $50, and have a shop weld it in. Thats the cheapest way to go and is just as good as the bolt on smsp.</TD></TR></TABLE>
No, don't do that. I tried it (so I could use a larger-diameter cat than the 2" stock-sized one) and they completely bungled it. They wanted to weld it into the exhaust system and header (!), which of course would have failed eventually from vibration, plus I wouldn't have been able to change the exhaust system later (which I did shortly after). I had them weld flanges on instead, and they used the rusty old nasty flanges instead of new ones, and it totally looked like crap. Figures... the one time I try going to a "shop" to get something done, it's a disaster.
Plus, it's really hard to find any shops willing to work with your parts. Most will outright refuse.
The original poster here just wants a cat for a stock exhaust, not a performance exhaust. Just get the Carsound "Direct Fit" cat for your car. It's around $100 on the internet, and already has the flanges and O2 bung(s) attached for your particular application. I ended up getting one of those and it fit perfectly. This is much cheaper than having someplace local weld some mess up for you, and it'll have factory quality and be made of all stainless steel, so you don't have to worry about rusting.
Edit: For people wanting a good cat with a larger internal diameter, to fit with a performance exhaust system, get one from SMSP. They use Carsound cats and weld the correct SS flanges onto them. They're a little pricey, but when you compare the cost of the universal Carsound cat plus the cost of SS pipe and flanges and most of all labor, it's quite reasonable, plus it's a much safer bet than taking it to some random local shop and hoping they do a good job.
Old Oct 3, 2007 | 05:02 PM
VR4ownzU's Avatar
Default Re: Cats for stock exhaust? (dwolsten)
According to this link the Direct Fit ones aren't available. Am I wrong or have the wrong site?
http://www.car-sound.com/02pro...tegra
Old Oct 3, 2007 | 05:45 PM
dwolsten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VR4ownzU &raquo;</TD></TR><TR><TD CLASS="quote">According to this link the Direct Fit ones aren't available. Am I wrong or have the wrong site?
http://www.car-sound.com/02pro...tegra</TD></TR></TABLE>
Good question. You're not wrong, nor do you have the wrong site. Unfortunately, Magnaflow/Carsound's information isn't complete. I had forgotten about this.
The car I got a cat for was a '00 GS-R. According to Carsound, they don't have a direct-fit application for that, but that's wrong. The 00-01 GS-R uses the same cat as the 96-01 RS/LS/GS. Here's the link where I got it, on a site called performance-curve.com: http://www.performance-curve.c...=1007
Hopefully that URL will work those interested; if not, just navigate to Exhaust &gt; Catalytic Converters &gt; By Application &gt; Acura &gt; Integra &gt; 96-99 4cyl - 1.8L &gt; GS, LS, RS.
Now for the ITR, I'm not really sure. I just checked the OEM part numbers at acuraoemparts.com, and while the '00 GS-R does use the same cat part number as the '00 LS, as I remembered, the '00 Type-R uses a different number, so I wouldn't bet on this one fitting your car.
Unless someone here knows more about the ITR catalytic converter, and if it's the same size as any other car's, I'd recommend giving SMSP a call. I'm sure they have one ready-made for your application.
Old Oct 3, 2007 | 05:57 PM
VR4ownzU's Avatar
On a side note... my gf needs a Cat for her 99 LS sedan. Will a 96 LS with its original 02 bolt directly on? It ran rich for a few days and killed it.
Anyways...I guess I'll check out SMSP if no one has a stock one for sale.
Old Oct 3, 2007 | 08:01 PM
dwolsten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VR4ownzU &raquo;</TD></TR><TR><TD CLASS="quote">On a side note... my gf needs a Cat for her 99 LS sedan. Will a 96 LS with its original 02 bolt directly on? It ran rich for a few days and killed it.</TD></TR></TABLE>
Yeah, the 96-01 LS should all be the same.
Old Oct 4, 2007 | 06:24 AM
Ed 341's Avatar
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwolsten &raquo;</TD></TR><TR><TD CLASS="quote">
Old Oct 4, 2007 | 06:35 AM
VR4ownzU's Avatar
Default Re: (Ed 341)
All the Type Rs on here and NO ONE has a stock cat they will sell?
Old Oct 4, 2007 | 06:37 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VR4ownzU &raquo;</TD></TR><TR><TD CLASS="quote">All the Type Rs on here and NO ONE has a stock cat they will sell? </TD></TR></TABLE>
Look in the September For sale thread I think I remember seeing one.
Old Oct 4, 2007 | 06:38 AM
Doostur's Avatar
^ Negative.
Old Oct 4, 2007 | 07:03 AM
Ed 341's Avatar
OP...someone answered your post on ITRCA. Do you need any appointments made or dry cleaning picked up?
Old Oct 4, 2007 | 07:28 AM
VR4ownzU's Avatar
Default Re: Cats for stock exhaust? (Ed 341)
The guy modified it to fit a bigger header... and I'm yet to hear back from him yet.
Ed 341
Jul 25, 2006 01:26 PM
gtarwiz
Feb 16, 2005 06:53 PM
stnwag0n
Nov 6, 2003 03:33 PM
95lsinteg
Nov 2, 2003 09:18 AM
xkhalil333x
Sep 26, 2003 02:44 PM
