H22 swap wont start
Old Oct 1, 2007 | 05:05 PM
he_who_corrupts's Avatar
Default H22 swap wont start
so attempted to finish a h22 swap on a 92 civic hatch, and the motor is in, conversion harness is put on, everything is fine, but the motor turns over and wont fire up. there was a weird buzzing noise coming from the main harness relay so i ordered a new one, plugged it in, and it made the same noise. the motor has spark since it pops with starting fluid, and it cant be the fuel pump because theres a brand new one in there. i am so confused on what is going on. any help with this would help guys.
Old Oct 1, 2007 | 05:34 PM
EJ1chevelle's Avatar
Default Re: H22 swap wont start (he_who_corrupts)
is the fuel pump priming when you turn the key to the "power" position but not start?
Old Oct 1, 2007 | 06:08 PM
Default Re: H22 swap wont start (93egB16A)
well only when you bypass the relay. otherwise when you leave the relay in it doesnt prime, but when you run a wire from the relay socket it primes but doesnt shut off. we tested another fuel pump also and it did the same thing.
nightrider93ex
Mar 12, 2008 08:33 AM
y0whuddupb
31
Aug 9, 2006 01:16 PM
Turbo_y8
Mar 5, 2006 11:38 PM
KRAWMAN
Jul 21, 2003 11:58 PM
