does 18a power steering pump fit on b16a?
Old Oct 1, 2007 | 04:59 PM
gray92hatch's Avatar
Default does 18a power steering pump fit on b16a?
As title says. Having a tough time finding a cheap b16 pump.
If it works, which belt do I use?
Thanx in advance.
Old Oct 1, 2007 | 05:42 PM
EJ1chevelle's Avatar
Default Re: does 18a power steering pump fit on b16a? (gray92hatch)
the pump itself should fit but you need the correct brackets... dont quote me on this but i used my EX pump with my b16 swap and its fine... it goes by the mounting hardware and brackets i beleive.
Old Oct 1, 2007 | 07:16 PM
geebs's Avatar
Default Re: does 18a power steering pump fit on b16a? (93egB16A)
ive got a nice pr3 b16a power steering pump.. ill sell it for $40 shipped..
but you need the b16 upper bracket.. if using a b16 head.. gsr bracket for gsr head..
Old Oct 5, 2007 | 03:34 AM
Default Re: does 18a power steering pump fit on b16a? (geebs)
So I guess any b series pump will work as long as I have the b16a bracket.
Someone correct me if i'm wrong.
Cheers
Old Oct 5, 2007 | 03:35 AM
pdiggitydogg's Avatar
you need to look this over
https://honda-tech.com/zerothread?id=1822781
(searching = good)
Old Nov 11, 2007 | 10:57 PM
mikey8422's Avatar
do you still have the pump ?
TUR3Ovtec
Aug 21, 2010 02:33 PM
royalrebel
Dec 11, 2009 08:57 AM
IndySporty
Jul 16, 2009 06:41 PM
Rok_Stok
15
Mar 13, 2009 04:32 PM
Si2See
Oct 31, 2008 01:50 PM
