B16a stroker
Old Oct 1, 2007 | 03:34 PM
Bsixteen_CRX's Avatar
Default B16a stroker
Does anyone know what the cheepest way to stroke a b16a is?
Old Oct 1, 2007 | 06:02 PM
zap's Avatar
zap
get an itr/gsr crank, order some decent rods/pistons.
Old Oct 1, 2007 | 06:11 PM
cartune network's Avatar
Default Re: B16a stroker (Bsixteen_CRX)
or just pickup an ls bottom end and throw some rods and pistons in it. not to mention its cheaper to do that then to stroke the b16a
Old Oct 1, 2007 | 06:16 PM
pythoner's Avatar
Default Re: (zap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zap &raquo;</TD></TR><TR><TD CLASS="quote">get an itr/gsr crank, order some decent rods/pistons.</TD></TR></TABLE>
If you wuld have read...you would have relized that he said B16A not B16B so he can no use those cranks
and to the OP you can use a B17 crank out of the DA integras but I would also say LS bottom
Old Oct 1, 2007 | 06:29 PM
Aquafina's Avatar
Default Re: (pythoner)
Easiest B17 crank/rods/pistons
Best 89mm crank, B16 rods, custom pistons
Old Oct 2, 2007 | 12:35 AM
zap's Avatar
zap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">If you wuld have read...you would have relized that he said B16A not B16B so he can no use those cranks
and to the OP you can use a B17 crank out of the DA integras but I would also say LS bottom</TD></TR></TABLE>
yes i do thats why i said get decent rods and pistons.
my bad, i should've said get Custom sized rods/custom pistons.
FYI, ive done this myself.. but on the expensive side by getting a 1.8L toda stroker kit for B16A way back in the day
Old Oct 2, 2007 | 05:12 AM
mikesrex's Avatar
You can run an LS crank, B16-length rods and custom pistons with the wristpin raised half the difference in stroke between the B16A and LS motors.
Or you can run a GSR/ITR crank, B17-length rods and off-the-shelf pistons designed for a 95mm stroker motor from what I understand.
The cool thing about the B16 stroker is it will give you a fatter powercurve than a longer-rod motor with the same stroke due to the increased piston speed.
Old Oct 2, 2007 | 11:58 AM
pythoner's Avatar
if that is true..I won't be selling my b16a that is sitting in the gradge
Old Oct 3, 2007 | 04:38 PM
mannyman2's Avatar
i have a stroked b16a. im running ls crank (89mm) ls crower rods, and custom off the shelf cp pistons(pin is moved up) i also sleeved my block to 84mm.... so i have a 2.0l.
sleeeper!!!!
Old Oct 3, 2007 | 09:20 PM
Default Re: (mikesrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikesrex &raquo;</TD></TR><TR><TD CLASS="quote">You can run an LS crank, B16-length rods and custom pistons with the wristpin raised half the difference in stroke between the B16A and LS motors.
The cool thing about the B16 stroker is it will give you a fatter powercurve than a longer-rod motor with the same stroke due to the increased piston speed.</TD></TR></TABLE>
how do i order custom pistons?
Old Oct 3, 2007 | 10:48 PM
Aquafina's Avatar
Default Re: (Bsixteen_CRX)
Contact someone on here who is a dealer for a piston company. They'll have a piston company listed in their sig.
Old Oct 4, 2007 | 09:30 PM
mannyman2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bsixteen_CRX &raquo;</TD></TR><TR><TD CLASS="quote">
how do i order custom pistons?</TD></TR></TABLE>u can call them directly and tell them what u are trying to build and they will be able to help u from there. its off the shelp pistons made secificaly for people stroking b16a's.
Old Oct 4, 2007 | 11:20 PM
Aquafina's Avatar
Default Re: (mannyman2)
See sig.
Old Nov 15, 2007 | 09:09 AM
bzyq2001's Avatar
how high can you rev engine with ls crank?
if i will live my pr3 pistons what compression i will have
Old Nov 18, 2007 | 04:58 AM
kpowerdhatch's Avatar
So can it be confirmed that a LS crank will drop into a b16a block? I know back in 04, Tech 43 had some custom Arias pistons to use with Ls crank and LS rods in a B16 block, but above it was stated that a LS crank and B16 rods with custom pistons will work?
Assuming you can drop in the LS crank, are b16 main bearings and LS main bearings the same specs?
Old Nov 20, 2007 | 10:26 AM
vtibrazil's Avatar
Default Re: (kpowerdhatch)
I am saving money to put a stroker kit on my B16, but i would like to know from who did it to their car and if it was worth the money..what would the best stroke 84.5mm, 87, 89mm what would give me the most power and torque... I plan on staying with 81.5mm piston and using some skunk2 pro 1 cams...please any input
Old Nov 20, 2007 | 10:31 AM
Aquafina's Avatar
Default Re: (vtibrazil)
LS crank will go in a B16 block with B16 rods using custom pistons. Rocket designed some pistons for someone to do this. No problems like some of the Tech43 setups either.
Old Nov 20, 2007 | 10:42 AM
vtibrazil's Avatar
Default Re: (Aquafina)
I live overseas so how difficult is it to buy an LS CRANK how expensive??? and how about those pistons difficult to get? This type of kit stroke can handle how many rpms??? Since the other stroker kits are forged would that necessarily mean you can rev to 9rpm on them without worry?
Old Nov 20, 2007 | 11:19 AM
acydphryck's Avatar
you should hit up Tech43...he 'built' a 2.0L B16 NA motor that made like over 200 whp on the dyno...for like 3 passes...and then it seized. apparently, he forgot to put in the thrust washers in the motor
Old Nov 20, 2007 | 11:24 AM
Aquafina's Avatar
You'd just have to source a LS crank. I can help you with the pistons. Rev to where it makes power, which won't be 9k.
Old Nov 21, 2007 | 11:05 AM
HYBRDcrx's Avatar
Just get a ls block with aftermarket rods and forged pistons. By the time you stroke the b16A you will have more money in the b16a then in a complete ls and have the same torque.
Old Nov 21, 2007 | 02:02 PM
Aquafina's Avatar
Default Re: B16a stroker (HYBRDcrx)
Powerband will be a lot different though.
Old Nov 21, 2007 | 05:42 PM
vtecsi00's Avatar
Default Re: B16a stroker (Aquafina)
i just bought a stroker kit from crowere and had it built to a 81.5 and 89 stroke and with upgrade in cams for $2500 and redlines at 9600rpm's
Old Nov 22, 2007 | 01:10 PM
vtibrazil's Avatar
Default Re: B16a stroker (vtecsi00)
and what can yo0u tell me about your kit sroke ...are you happy about it?? how is the power compared to before. Since I canīt buy a block and send it to brazil i am looking at doing such a thing if it is worth it....
Old Nov 22, 2007 | 02:21 PM
Aquafina's Avatar
Default Re: B16a stroker (vtibrazil)
Is there a law or something when it comes to importing? If not, I'd just get a 1.8 block.
