oil squiters?
just trying to get more oil to the pistions, and i thaught it would be a good idea to add oil squiters cause i plan on adding ctr pistions with a fully built bottom end...any suggestions on getting more oil to lubrciant the pistions before i damage something..
ight know iam running jdm itr pistions and the bottom end is built with acl bearings and rod bolts and its tunned. only thing i haven't changed was the connecting rods.. the reason for the oil squiters was beacause i just read a article saying how the ls bottom has a bad r/s ratio it would last do to the lack of oil squiters to cool the pistions and other b/s. i put alot of time and money into my build and don't want to blow it, iam just looking for a way to cool the pistions. you think the ctr pistions are a bad choice? iam just trying to up my comp. ratio a little more..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsweez »</TD></TR><TR><TD CLASS="quote"> iam just trying to up my comp. ratio a little more.. </TD></TR></TABLE>
There are much better ways of finding power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
There are much better ways of finding power.</TD></TR></TABLE>
ok how is this my friend i did the basics, and only thing left to do is upgrade the cams, get cam gears and degree them..but iam still worried about cooling the pistions and the bad r/s ratio that sh*t is really bugging me.
the itr and gsr have almost the same r/s ratio as the ls,and the go 8500+rpms all the time. the oilsquirters wont hurt anything but if your bearing clearances are good then it will last a long time{assuming you have arp rod bolts}. also if that was the case then why do people out ls internals in gsr blocks and plug off the squirters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch »</TD></TR><TR><TD CLASS="quote">the itr and gsr have almost the same r/s ratio as the ls,and the go 8500+rpms all the time. the oilsquirters wont hurt anything but if your bearing clearances are good then it will last a long time{assuming you have arp rod bolts}. also if that was the case then why do people out ls internals in gsr blocks and plug off the squirters
good point...so basically what i read was b/s my motors good as any other well built honda motor without the oil squiters and block guard?
</TD></TR></TABLE>good point...so basically what i read was b/s my motors good as any other well built honda motor without the oil squiters and block guard?
yep, as long as your bottom end has a good blueprint and you did the rodbolts your set. theres lots of guys on here with that setup that have been running them for years
good point...so basically what i read was b/s my motors good as any other well built honda motor without the oil squiters and block guard?</TD></TR></TABLE>
At what point is the ratio of rod length to stroke length considered bad? I've always wondered this.
GSR/ITR = 1.58
B18a/b, B20b/z = 1.54
So, is bad like 1.56?
Now consider what the differences between the two R/S ratios will theoretically do for your particular motor and design it with that in mind.
Theoretically, the higher R/S ratio motor will make peak power more to the right on a graph than the lower R/S ratio motor.
GSR/ITR = 1.58
blue print is just careful and measuring and machning of all aspect of your bottom end.
yeah a b16 has a great r/s ratio but you have to rev it to over 9000+ to make peak power and is still torqeless with no mid range, the 1.8's have a lower r/s ratio but make peak power lower and still make good mid range power/torqe.
as long as you build your motor{cams,intake,header,etc} around what it will give you the best{mid range/torqe} youll have a happy motor. that was a great point bambam
as long as you build your motor{cams,intake,header,etc} around what it will give you the best{mid range/torqe} youll have a happy motor. that was a great point bambam[/QUOTE] gotcha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">
GSR/ITR = 1.58
Theoretically, the higher R/S ratio motor will make peak power more to the right on a graph than the lower R/S ratio motor.</TD></TR></TABLE> gotcha
thankz
what about ctr pistions in an lsv setup thoug good or bad idea
GSR/ITR = 1.58
thankzwhat about ctr pistions in an lsv setup thoug good or bad idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsweez »</TD></TR><TR><TD CLASS="quote">as long as you build your motor{cams,intake,header,etc} around what it will give you the best{mid range/torqe} youll have a happy motor. that was a great point bambam</TD></TR></TABLE> gotcha
gotcha
thankz
what about ctr pistions in an lsv setup thoug good or bad idea[/QUOTE]
I'm not usually a dick (at least I don't think I am), but I'm going to recommend using the search button. Honestly, this is probably the most documented topic on honda-tech. Plus, I'm off to the titty bar w/ a few of the girls so I don't have much time to respond right now...
gotcha
thankzwhat about ctr pistions in an lsv setup thoug good or bad idea[/QUOTE]
