filler rod selection
Old Oct 1, 2007 | 12:08 PM
55superbeetle's Avatar
Default filler rod selection
Which filler rod should i be using to weld a stainless v band flange to an exhaust housing? Aslo when welding 304 to a mild steel flange?
Thanks
Old Oct 1, 2007 | 01:32 PM
Gtijosh's Avatar
Default Re: filler rod selection (55superbeetle)
308L on both. You may get some rust on your dissimalar weld though. but it is what it is
Old Oct 1, 2007 | 01:55 PM
Default Re: filler rod selection (Gtijosh)
Thanks!
I think ive been using 309 on the runners themselves is that the correct rod?
Old Oct 1, 2007 | 02:15 PM
k24em2's Avatar
For 304-304 stainless welds use 308L rod, for mild-304 use 309L. For the exhaust housing-vband weld I would use 309L.
Old Oct 2, 2007 | 03:25 AM
dfoxengr's Avatar
Default Re: filler rod selection (k24em2)
check my site under articles and welding, or maybe links and welding, i forget, theres some good charts on rod selection
http://www.foxraceco.com
good luck
-derek
Old Oct 2, 2007 | 10:14 PM
MADMAX_zero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gtijosh &raquo;</TD></TR><TR><TD CLASS="quote">308L on both. You may get some rust on your dissimalar weld though. but it is what it is </TD></TR></TABLE>
Woh dood. 304 to mild calls for 309, not 308.
TIGboy
Welding / Fabrication
21
Dec 3, 2011 04:45 PM
TurboEK9Coupe
Jun 3, 2008 09:58 AM
all_motor_mike
Jan 26, 2008 02:08 PM
.john.
Sep 4, 2007 06:39 AM
JDMCRX
Sep 6, 2006 03:43 PM
