another year..another failed emissions test.
Anyone know what I need to do to fix this? Here are the numbers
High Speed
RPM: 2279
HC: 167 - 41 Pass
CO: .94 - .02 Pass
CO2: 13.9
O2: 0.9
Nox: 1240 - 3857 Fail
Dilution: 13.92 Pass
Low Speed
RPM: 1930
HC: 173 - 86 Pass
CO: .97 - .04 Pass
CO2: 13.8
O2: 1.1
Nox: 1372 - 4016 Fail
Dilution: 13.84 Pass
The guy said I needed a new cat converter but I really don't know what would make my nox go down. Anyone have any ideas?
High Speed
RPM: 2279
HC: 167 - 41 Pass
CO: .94 - .02 Pass
CO2: 13.9
O2: 0.9
Low Speed
RPM: 1930
HC: 173 - 86 Pass
CO: .97 - .04 Pass
CO2: 13.8
O2: 1.1
This may be of some help:
https://honda-tech.com/zerothread?id=853679
Yes its for Cali, but theres some good info in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 »</TD></TR><TR><TD CLASS="quote">nox is created by tempretures above 2500 degrees in the cylinders...egr cools down the cylinders.... the egr is the only component that controls nox.</TD></TR></TABLE>
Only problem is that in 92-00 USDM civics, the only ones equipped with an EGR system were the HX or VX's , Otherwise, its on JDM motors such as the JDM D15b as far as i know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 »</TD></TR><TR><TD CLASS="quote">i have a jdm d15b and has no egr...</TD></TR></TABLE>
I have the JDM D15b as well, the OBD2 version that is 3-stage VTEC, not the OBD1 regular VTEC.
The manifold came with a block-off tray from the company i ordered it from because USDM civics dont use an EGR system, but this motor did. I long since swapped manifolds tho.
i really dont think it does..im not 100% positive though. Would an ECU change the nox? I know my old skunk2 ecu use to run really rich and it would fail me in in HC and CO but not NOX. I was running on 93 octane if that changes much? I really don't know..haven't changed anything since last emissions except my ecu.
Like some people have stated NOX is high combustion temps. Cat WILL NOT fix this and EGR isnt the only thing you can do to drop them.
What is your timing set at? If you retard it, it will lower the temps, also get a few steps colder plugs. Try this and see where this puts you at.
EDIT: Actually those are way way high what did you get last year?
These are my numbers from 2 years ago with the skunk2 ecu. I am running phearable now.
High Speed
RPM: 2188
HC: 147 - 234
CO: .82 - 5.35
CO2: 11.0
O2: 14.2
Nox: 1072 - 186
Dilution: 16.3
Low Speed
RPM: 1828
HC: 152 - 251
CO: .85 - 5.74
CO2: 10.8
O2: 17.1
Nox: 1186 - 129
Dilution: 16.5
High Speed
RPM: 2188
HC: 147 - 234
CO: .82 - 5.35
CO2: 11.0
O2: 14.2
Nox: 1072 - 186
Dilution: 16.3
Low Speed
RPM: 1828
HC: 152 - 251
CO: .85 - 5.74
CO2: 10.8
O2: 17.1
Nox: 1186 - 129
Dilution: 16.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">yo im not trying to thread steal or bump in, because i have never had an emission test in my life.. but what happens if you fail? do they not let you drive your car?</TD></TR></TABLE>
You get a failed sticker on your window, and a repciept telling you that you have a certain amount of days to get it fixxed and then return. If cops are nearby and see a failed sticker, thats just a reason for them to pull you over and hassle you.
Herbie
Nov 6, 2006 07:45 AM
EFin' Kyle
Feb 9, 2006 05:50 PM
That'll cool her down
