what brake pads do i get for 96 honda civic hb with b series swap?
Old Oct 1, 2007 | 07:28 AM
Pnoyej6's Avatar
* B A N N E D *
Default what brake pads do i get for 96 honda civic hb with b series swap?
do i get 96 civic brake pads or integra pads? are they same part number? What do you guys recommend oem or hp hawk pads for turbo
Old Oct 1, 2007 | 07:42 AM
timmybilt's Avatar
Default Re: what brake pads do i get for 96 honda civic hb with b series swap? (BALISTIKPNOY)
you need the brake pads for whatever brakes your running or if you have stock brakes just go get pads for your model car. im assuming by the title that you seem to think your brakes have been swapped along with the motor, but that is not necessary just for a b swap so im guessing you still have your stock brakes
Old Oct 1, 2007 | 07:43 AM
gsxr1k05's Avatar
if you did not upgrade your front rotors and assume you still have rear drums, you get the brakes for your model car. swapping the engine does not magically give you a way to get brakes for the car the engine came out of.
i am going to upgrade to ebc myself, but i always have used oem.
Old Oct 1, 2007 | 08:44 AM
Pnoyej6's Avatar
* B A N N E D *
Im not sure, since I purchase car used last year with b series swap. I still have the rear drums btw. So i just get stock honda civic brakes. So when you do b series swap on ek's crx, the civic brakes/rotors are interchangeable/
Old Oct 1, 2007 | 08:46 AM
philosofy1's Avatar
Default Re: (BALISTIKPNOY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALISTIKPNOY &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure, since I purchase car used last year with b series swap. I still have the rear drums btw. So i just get stock honda civic brakes. So when you do b series swap on ek's crx, the civic brakes/rotors are interchangeable/</TD></TR></TABLE>
yes they are interchangable. that's what makes honda so great! well, atleast one of the things. as for your brakes, if you have a 96 civic hatch, then get brakes for a 96 civic hatch.
IP RACING
18
Apr 28, 2009 12:37 PM
nextgtr
19
Aug 27, 2006 08:38 PM
mr2
Jul 30, 2004 02:55 AM
EL-Driver
Nov 12, 2002 04:57 PM
WuShu
May 18, 2001 12:43 PM
