wont go into gear
i had the same problem but it was all gears. try pumping the clutch a few times before you put it in gear. i think it might be the master/slave cylinder.
Rev only, I vote for a bad (thin) clutch, how far down do you have to push the clutch pedal to get into a fwd gear, how far off of the floor before the clutch engages and you can drive away in 1st, getting near the top end of travel??
mine does this sumtimes... but when it does this it doesnt wanna go into first so I throw it in 2nd n rev it up a little n let off the clutch jus a little pull it out of 2nd n throw it in rev or 1st depending on what gear Im trying to get it into..
dunno if that made since at all but I tried...
Bowl_of_Rice
Dec 29, 2011 05:34 PM
supercivicstack
Sep 12, 2009 02:24 PM
jwshilli
Jul 14, 2009 03:02 PM
