Ebrake light stays on
Old Sep 30, 2007 | 06:19 PM
Thizzed Out's Avatar
Default Ebrake light stays on
my e-brake stays on even when its all the way. what things should i check? its a 1990 ex. thanks
Old Sep 30, 2007 | 07:10 PM
dang_erous's Avatar
Default Re: Ebrake light stays on (Thizzed Out)
you might be low on brake fluid......happened to me
Old Sep 30, 2007 | 07:12 PM
Desiss's Avatar
yea check the brake fluid, very common in honda's....if that doesn't solve it, then get the brakes checked immediately because it could be a serious brake problem, since it is a red light coming on
Old Sep 30, 2007 | 07:16 PM
Default Re: Ebrake light stays on (Desiss)
i checked both the brakes and the fluid. they are both fine. i just replaced the brakes like a month ago. anything else to look for?
Old Sep 30, 2007 | 07:22 PM
sony224422's Avatar
air might be in the system.. did you bleed it properally?
00BaseRacer
Apr 12, 2007 12:16 PM
JDM_SOHC
12
Nov 29, 2005 06:01 AM
sullycrx
Nov 16, 2005 09:48 PM
01SilverGSR
Dec 29, 2002 11:59 AM
Padronis
Jun 29, 2002 07:00 AM
