99 Accord will not start
Old Sep 30, 2007 | 04:28 PM
Paladin322's Avatar
Default 99 Accord will not start
Hey guys, I am new to the forum and I need some help. I have a 99 Accord with a manual transmission and when I try to start it nothing happens no clicking and no dimming of lights. I have checked the connections on the battery and they're tight. I'm thinking it could be the switch associated with the clutch pedal. Unfortunately, I don't know where it's located. Could someone help with this or offer other suggestions?
Brian
Old Oct 2, 2007 | 11:40 AM
Bozok's Avatar
Default Re: 99 Accord will not start (Paladin322)
That's true, it could be the clutch switch. I have a '94 Accord, so I don't know how different my setup is from your '99 Accord. But on mine, you would just look at the top of the pedal, sticking your head where your feet normally go. There is a switch there with 2 pins. There should be no continuity between them with the clutch release, and continuity with the clutch depressed. Check for continuity with the clutch pedal pushed in. If there is none, then adjust it or replace it. If there is continuity with the clutch pedal pushed in, then you have some other problem.
To check for continuity, turn the key to the run position, push the clutch pedal in, and put a voltmeter's probes one on each wire. If there is voltage, then you have continuity.
Old Oct 2, 2007 | 02:18 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
have you tried to compression start it??
Old Apr 27, 2009 | 05:04 PM
brian5888's Avatar
New User
I have a 94 Accord w/ manual trans that has similar symptoms. No start, no solenoid click, battery and connections good, fuses look good, starter passed Autozone tester.
I found that the little plastic pad connected to the clutch pedal that pushes the clutch pedal switch plunger in had broken off so I replaced it but it didn't help.
How can I test the clutch pedal switch without a volt meter? It seems a big coincidence that it would be the ignition switch or starter relay since the little pad on the clutch pedal just broke off. Is that a good assessment?
czego82
Oct 11, 2017 11:55 AM
Cpt Marvel
Apr 12, 2010 06:17 PM
Jeff463
Oct 10, 2009 07:35 PM
Shamus1
Apr 1, 2005 04:27 AM
cwoolsey
Aug 11, 2002 01:50 PM
