How hard to install y8 intake mani in a y8
Old Sep 30, 2007 | 03:19 PM
jdejesus3's Avatar
Default How hard to install y8 intake mani in a y8
I got an automatic y8 intake mani to go in my y7 engine. I noticed 2 hoses that dont really match anywhere from my engine to the mani. They just dont seem to go anywhere in the y8 mani. Anyone know about changing these manifolds??
Also some pic instructions would be super helpful.
Old Sep 30, 2007 | 03:21 PM
Jakester9500's Avatar
I just want to make sure, but your car is an automatic, right? Otherwise, you might have a little more trouble than you think you will
Old Sep 30, 2007 | 03:39 PM
Syndacate's Avatar
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">I just want to make sure, but your car is an automatic, right? Otherwise, you might have a little more trouble than you think you will</TD></TR></TABLE>
No he won't, it's fine either way - the Y7 just has a IACV to TB setup like the Y8 auto, not the Y8 manual. Putting a manual Y8 on is a pain in the *** - gotta weld up the old IACV holes 'n ****.
Old Sep 30, 2007 | 03:41 PM
97Ej6mike's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
No he won't, it's fine either way - the Y7 just has a IACV to TB setup like the Y8 auto, not the Y8 manual. Putting a manual Y8 on is a pain in the *** - gotta weld up the old IACV holes 'n ****.</TD></TR></TABLE>
Oh the pains i have had in my *** over the y7/y8 issues...
Using a Y7 tb on a y8 Auto manifold should work just fine.
Old Oct 1, 2007 | 02:51 PM
jdejesus3's Avatar
Default Re: How hard to install y8 intake mani in a y8 (jdejesus3)
I got y8 everything, fuel rail, injectors, throttle body, everything but just two hoses dont match on my y8 though from the y7. ( I got auto y8 mani going into y7 auto engine.) Will I encounter any problems with this mani swap? any other things to worry about??
Old Oct 1, 2007 | 05:34 PM
Sundown's Avatar
why would you weld the old iacv holes? I left the iacv on the back of the manifold and it does just fine...plus if you weld them up, and decide to go obd1 or do a mini-me, you're going to need a new manifold
OP: make sure you get all the old gasket off the head and manifold, mark the tps/map sensor plugs because they use the same type of plug and you should be fine. Also dont forget to get some coolant because youre going to lose some..
StuckInTexas
Feb 12, 2015 10:38 PM
Hondakid95
Engine Management and Tuning
Dec 29, 2011 02:00 PM
92civic_eg
Aug 18, 2004 06:24 PM
tylerdurden
Jan 31, 2003 11:50 AM
