serious issue.
Old Sep 30, 2007 | 02:42 PM
93ej1coupe's Avatar
Default serious issue.
ok idk if this is serious or if im just a ******* retard.
my cam gear wont BUDGE... went to put timing belt on the motor i just swapped... cam gear wont budge to set the timing... cam is locked up and i dont know why.
Anyone got any ideas?
Thanks
-Derek
Old Sep 30, 2007 | 02:54 PM
hondamark35's Avatar
Default Re: serious issue. (93ej1coupe)
what are you using to try to turn it? it's probably not going to turn by hand. wrench or long handle wratchet work well if you put them on the cam gear bolt.
Old Sep 30, 2007 | 03:14 PM
93ej1coupe's Avatar
did that... it just tightens bolt and its torqued and it still turns it will snap...
lurice01
12
Feb 22, 2017 07:56 PM
kornerk12
Dec 5, 2008 11:48 AM
buck02
Jan 12, 2004 02:52 AM
rasta420
Oct 1, 2003 07:53 PM
