Idle Problems
Old Sep 30, 2007 | 02:15 PM
sanegb16's Avatar
Default Idle Problems
I cleaned my injectors in my b16a2 and almost have my build complete but its not idleing properly
it will idle for a minute then just cut out
i cannot tell what the idle is either since its a dx model
i am stumped on what could be happening
firing orders correct
grounds are good
dunno what else
Old Sep 30, 2007 | 02:19 PM
sanegb16's Avatar
Default Re: Idle Problems (sanegb16)
also i do not have my o2 sensor plugged in
what color wires are on the o2 sensor
Old Sep 30, 2007 | 02:42 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanegb16 &raquo;</TD></TR><TR><TD CLASS="quote">also i do not have my o2 sensor plugged in
what color wires are on the o2 sensor</TD></TR></TABLE>
Dont know of the colors off the top of my head ( 2 blacks, a white and a blue?)
But yea, if you dont have a primary 02 sensor reading that would explain why your motor isnt running correctly. What ECU are you running for the motor?
Old Sep 30, 2007 | 04:47 PM
sanegb16's Avatar
Default Re: Idle Problems (97Ej6mike)
chipped p28
Old Oct 9, 2007 | 02:04 AM
civiccoupegsr's Avatar
i would said re-check the third ground from the motor...the one by the theromosta...the one that has little wires....if those two wires is loose the car will sometime bogs, miss fire....
GTEC913
Jul 1, 2008 02:11 AM
spike
Jan 15, 2003 05:30 AM
