civic not starting
Old Sep 30, 2007 | 01:23 PM
allmotorkilla03's Avatar
Default civic not starting
i have a 94 eg coupe with a 98 non vtec sohc motor it has the 98 wiring for the motor but i decided to drop the motor but it ran before i dropped it and then i have to put it back in for certain reasons but now the car gets no power i connected all the harnesses i was thinking it was a bad ground wire im not sure how many ground wires i need but i only see two that are bolted down anyone got any hints for me?
Old Sep 30, 2007 | 02:06 PM
sanegb16's Avatar
Default Re: civic not starting (allmotorkilla03)
did u hook up the fuse box?
Old Sep 30, 2007 | 02:08 PM
NismoGriff's Avatar
Default Re: civic not starting (sanegb16)
Ground wires at the thermostat housing connected??
Old Sep 30, 2007 | 02:25 PM
yes ground wires at thermostat is connected, and yes the fuse box is connected
Old Sep 30, 2007 | 02:27 PM
sanegb16's Avatar
Default Re: (allmotorkilla03)
just to double check you you have one wire from the harness to the fuse box and one from the positive terminal of the bat correct?
Old Sep 30, 2007 | 02:47 PM
correct i just went out side n check the battery i bought the battery brand new i works for a fact i know that but when i the terminals on they dont spark at all nothin happens
Old Sep 30, 2007 | 05:53 PM
NismoGriff's Avatar
So, you have ground from battery to chassis, from chassis to transmission, from valve cover to core support, the thermostat grounds are hooked up and you have both wires leading into the fuse box hooked to the proper terminals and you have NO POWER what-so-ever?
Old Sep 30, 2007 | 09:27 PM
i will def check all those locations tommorrow
hybrid1990crx
Oct 15, 2010 04:35 PM
rick_rabies
May 2, 2009 11:24 AM
redman223
Audio / Security / Video
May 4, 2007 02:51 PM
96SIR
Dec 19, 2006 08:08 PM
Full Race A6
Jan 30, 2004 08:38 AM
