Need help! obd0-obd1 question
Ok, i have a 1990 civic si and i boosted it a while ago. I got an obd0-obd1 conversion on it so it could be tuned with uberdata. Now i am taking off the turbo because i need a more reliable car for school. I was wondering if i needed to get an obd0 map-sensor, ecu, and distributor to have it run good or if i can just take the tuning chips off the obd1 ecu to make it run right. May be a dumb question,lol.
thanks
thanks
just take the turbo off and put a header on and you are done. the car should actually drive pretty close to stock. the computer is just going to use the vacuum portion of the fuel map so you dont need to change anything.
