Few quick questions for my suspension/brake conversion setup...
The chassis is a 94 civic hatch. I am in the process of doing a 99/00 Civic Si conversion on it and have a few questions for aftermarket parts for this...
First, for LCA's, i was told/read that I need to use 94-00 Integra LCA's for this conversion, so before I buy new ones I just want to verify this.
And if I'm using Integra LCA's, I would then need to use a sway bar for the same? I'm also considering the the ASR subframe brace, it's listed as compatable with 9-95 civics and 94-00 integra's, so I'll be good to go with this also correct?
And for the front, I can use any suspension components for a 92-95 civic or 94-00 integra right?
Thanks in advance for any help
Yes, you'll need the front and rear LCA"s from a 92-05 Civic or 94-01 Integra, you can't use the ones from the Si. The ASR subframe brace + swaybar will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance »</TD></TR><TR><TD CLASS="quote">Yes, you'll need the front and rear LCA"s from a 92-05 Civic or 94-01 Integra, you can't use the ones from the Si. The ASR subframe brace + swaybar will work. </TD></TR></TABLE>
great, thanks for the reply
and with the front, I'm good with using anything for a 92-95 civic or 94-01 Integra right? I'm using the 99/00 front brakes also, if i didn't mention that before...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 »</TD></TR><TR><TD CLASS="quote">
and with the front, I'm good with using anything for a 92-95 civic or 94-01 Integra right? I'm using the 99/00 front brakes also, if i didn't mention that before...</TD></TR></TABLE>
just need to confirm this b/c I am using the SI spindles....
ttt
ttt
95civiccpdx
Aug 3, 2009 11:44 AM
Captain JDM
Suspension & Brakes
Mar 20, 2007 12:48 PM
